The reason for my subject being I have two BluRays that are not completing the MakeMKV process properly after trying multiple different drives. I am able to use PowerISO to create a 1:1 copy of the disc into a .iso file. I am wondering if MakeMKV is able to recognize a virtually mounted .iso file as a normally inserted BluRay disc and run the process as normal? Has anyone tried this and were you successful? I searched the forum for iso information and nothing came up, so I'm assuming it's not possible, but I am trying to dig for any kind of workaround at this point to complete my collection!
.iso to MKV using MakeMKV?
Re: .iso to MKV using MakeMKV?
There is information necessary for dealing with BDs that isn't included in ISO files, from what I see. You will probably get a message about "Volume key is unknown for this disk" if you attempt to open them.
ISOs of DVDs work pretty well, because everything you need to decode them gets included in the ISO.
Searching for "ISO" won't work because the forum software won't index any words shorter than 4 letters. Google can find them, though.
DavidHOO
Search "Convert Blu-ray ISO image to MKV with MakeMKV", there are many guides may help you.
woodpost
don't mount the ISO. just ctrl-o in makemkv and select the .iso file. this works for me, at least with ISOs created by AnyDVD.
paulster
Exactly. I convert probably 99% of my BDs this way, because I back them up to ISO first using AnyDVD for archiving and then use MakeMKV against the ISO as it's quicker than reading the disc a second time.woodpost wrote:don't mount the ISO. just ctrl-o in makemkv and select the .iso file. this works for me, at least with ISOs created by AnyDVD.
ChicagoJoe69
What are you using to make .iso's from the BD's? Is there a free solution? On the ones I've tried the free version is limited to a useless size.
BTW, my goal is to clone a BD. In theory creating an .iso and then burn from that, unless there is a better way.
