Hi all!! My questions is very simple. I have a multimedia HDD and don't play High@L5.1 but can do it on High@L4.1
I tried to create a MKV with MakeMKV but...don't work on my HDD
So.... i want to know what is code profile of created MKV
Thanks in advance
MadeMKV creates a High@L5.1 or High@L4.1 file???
Re: MadeMKV creates a High@L5.1 or High@L4.1 file???
According to mediainfo, they are High@L4.1. (for AVC encoded movies, VC-1 movies have a different output)
makemkv copy stream from the bluray, so the resulting mkv is EXACTLY what was on the bluray disk!
Blurays are profile high@level 4.1
again, MakeMKV does NOT reencode stream.
Uhmmmm, ok...... so, i don't know what is my problem.....
i had a blusens T60 multimedia system...
anybody knows it????
Install mediainfo (linked in thread above) and check whether your MKV is AVC (H264) or VC-1 encoded. According to http://www.blusens.com/en/products/digital-home/T60/ your device is capable of playing H264, but VC-1 isn't mentioned there. You can use Handbrake to convert it from VC-1 to H264.
that site also mentions high @4.0
4.0 will severely limit the bitrate it can play. the 4.0 could be a typo though..
This is a mediainfo list:
Video
Formato : MPEG Video
Formato de la versi?n : Version 2
Formato del perfil : Main@Main
Ajustes del formato, BVOP : No
Ajustes del formato, Matrix : Predeterminado
ID C?dec : V_MPEG2
ID C?dec/Info : MPEG 1 or 2 Video
Duraci?n : 49min.
Tipo de tasa de bits : Constante
Tasa de bits : 7 000Kbps
Ancho : 720pixeles
Alto : 576pixeles
Relaci?n de aspecto : 4:3
Velocidad de cuadro : 25,000fps
Est?ndar : PAL
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8bits
Tipo de exploraci?n : Entrelazado
Orden de la exploraci?n : Campo superior primero
Bits/(Pixel*cuadro) : 0.675
Tama?o de pista : 2,37GIB (90%)
I thinks is a simple MPGE codification
source is a documental fron BBC DVD so, Why can't see it??? brrrr is a pity, cause makeMKV is the best encoder...i would to use it always.....
In the other hand i was capable to see on Blusens T60 MKV high@L4.1 clearly but not high@L5.1...
firmware issue i guess
any idea??
Video
ID C?dec : V_MPEG2
Duraci?n : 49min.
Ancho : 720pixeles
Alto : 576pixeles
Est?ndar : PAL
ColorSpace : YUV
any idea??
Your player probably cant play mpeg2 in mkv container... many standalones cant/dont allow it in the firmware...
Also most players (besides software decoders) cant play H.264 high@5.1...
