The Dark Tower Bluray
WynsWrld98
#1 Post by WynsWrld98 » Wed Nov 01, 2017 9:39 pm
Tried it in two Bluray PC drives, won't work in either to rip main movie (did rip deleted scenes title). Disc doesn't have a mark on it. I tried to increase the retry count per suggestion in FAQ and made no difference. Here's what I get trying to rip it with one of my drives:
MakeMKV v1.10.7 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading 'HD-DVD-ROM HL-DT-ST BD-RE GGW-H20N XJ03' at offset '19071039488'
File 00102.mpls was added as title #0
File 00001.mpls was added as title #1
Title 00002.mpls is equal to title 00001.mpls and was skipped
Title 00003.mpls is equal to title 00001.mpls and was skipped
File 00354.mpls was added as title #2
Title #00355.mpls has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00356.mpls has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00357.mpls was added as title #3
Title #00358.mpls has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00359.mpls was added as title #4
Title #00361.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00362.mpls has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00363.mpls has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00364.mpls was added as title #5
Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00099.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00208.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00249.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00220.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00228.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00221.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00222.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00223.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00224.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00225.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00226.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00227.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00229.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00334.m2ts was added as title #6
File 00335.m2ts was added as title #7
File 00336.m2ts was added as title #8
File 00337.m2ts was added as title #9
File 00338.m2ts was added as title #10
File 00339.m2ts was added as title #11
Title #00340.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00341.m2ts has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00342.m2ts was added as title #12
Title #00343.m2ts has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00344.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00345.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00346.m2ts has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00347.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00348.m2ts has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00349.m2ts was added as title #13
File 00350.m2ts was added as title #14
File 00351.m2ts was added as title #15
File 00352.m2ts was added as title #16
File 00353.m2ts was added as title #17
Title #00354.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00365.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 2 titles into directory M:/! 1 Bluray Rips to ISO HUGE FILES
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '19071039488'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '18644140032'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '18644140032'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '18644398080'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '18644398080'
Failed to save title 1 to file M:/! 1 Bluray Rips to ISO HUGE FILES/Dark_Tower,_The_(2017)_t01.mkv
Encountered 12 errors of type 'Read Error' - see /errors/read/
1 titles saved, 1 failed
yorgo
Re: The Dark Tower Bluray
#2 Post by yorgo » Wed Nov 01, 2017 9:58 pm
Looks like the disc may be damaged (whether it shows visible damage or not), here's an older response to a similar error report from Mike:
https://www.makemkv.com/forum2/viewtopic.php?f=8&t=4564
