War of the Planet of the Apes 3d No FUTs
bradleyrealtor
FYI not working (no FUTs) for the 3d version.
bradleyrealtor
Re: War of the Planet of the Apes 3d No FUTs
dump file sent
dmillionz
Any progress on the 3D version?
dmillionz
I'm confused. If the problem has been resolved for the standard blu-ray version, why the long delay resolving the issue for the 3D version?
dmillionz
It's working now for 3D. Thanks.
scanfff
I'm still getting no FUTs on the standard Bluray.
In Preferences->General, do you have "allow contacting website for updates" checked? If not, MakeMKV cannot pick up new SVQ files when needed.
See /svq/ for more information.
scanfff
Woodstock - Thank you that did it
CineMan
so i send my dumpfile. For me FUT not working.
And yes, MK is open for updates from the server.
The normal BD from the 2-Disc Edition works fine.
But not the 3DBD...
Regards
Cine
But not the 3DBD...
Regards
Cine
CineMan
so, after a very long night, i also try f*b driver. It shows me the playlist 800.
So, it is same what i used with makemkv. The jumping point is, that when i rip
to mkv then i have stuttering, and lots of pixels, blocks and colourchange problems
when i play the movie. The non3D BD Disk works fine with makemkv. When i rip
the full disk with f*b driver aktiv, then the stream play fine, without any problems.
Is this a new kint of protection ? or is there a problem during ripping.
Normaly i use the Linux Version, but ist mor complicate to update.
Anyway, on both systems i had this issue. Three other movies run
perfectly with the same version. On Linux i use .6 not .8
Regards
Cine
Regards
Cine
dmillionz
We watched the ripped MKV 3D version a few weeks ago with no issues at all.CineMan wrote:Hi,
Regards
Cine
CineMan
hm...is makemkv shown you the right fut ?
sometimes it is mysterious
Cine
Cine
