War of the Planet of the Apes 3d No FUTs
Everything related to Blu-ray 3D and 3D MKV files
bradleyrealtor
#1 Post by bradleyrealtor » Tue Oct 31, 2017 8:57 pm
FYI not working (no FUTs) for the 3d version.
bradleyrealtor
Re: War of the Planet of the Apes 3d No FUTs
#2 Post by bradleyrealtor » Tue Oct 31, 2017 9:06 pm
dump file sent :D
dmillionz
#3 Post by dmillionz » Fri Nov 03, 2017 4:50 am
Any progress on the 3D version?
dmillionz
#4 Post by dmillionz » Mon Nov 06, 2017 5:20 am
I'm confused. If the problem has been resolved for the standard blu-ray version, why the long delay resolving the issue for the 3D version?
dmillionz
#5 Post by dmillionz » Tue Nov 07, 2017 8:22 pm
It's working now for 3D. Thanks.
scanfff
#6 Post by scanfff » Fri Nov 17, 2017 12:45 am
I'm still getting no FUTs on the standard Bluray.
#7 Post by Woodstock » Fri Nov 17, 2017 3:28 am
In Preferences->General, do you have "allow contacting website for updates" checked? If not, MakeMKV cannot pick up new SVQ files when needed.
See /svq/ for more information.
scanfff
#8 Post by scanfff » Fri Nov 17, 2017 8:12 am
Woodstock - Thank you that did it :)
CineMan
#9 Post by CineMan » Fri Dec 08, 2017 11:47 pm
so i send my dumpfile. For me FUT not working.
And yes, MK is open for updates from the server.
The normal BD from the 2-Disc Edition works fine.
But not the 3DBD...
Regards
Cine
CineMan
#10 Post by CineMan » Sat Dec 09, 2017 3:04 pm
so, after a very long night, i also try f*b driver. It shows me the playlist 800.
So, it is same what i used with makemkv. The jumping point is, that when i rip
to mkv then i have stuttering, and lots of pixels, blocks and colourchange problems
when i play the movie. The non3D BD Disk works fine with makemkv. When i rip
the full disk with f*b driver aktiv, then the stream play fine, without any problems.
Is this a new kint of protection ? or is there a problem during ripping.
Normaly i use the Linux Version, but ist mor complicate to update.
Anyway, on both systems i had this issue. Three other movies run
perfectly with the same version. On Linux i use .6 not .8
Regards
Cine
dmillionz
#11 Post by dmillionz » Sun Dec 10, 2017 7:23 am
CineMan wrote:Hi,
Regards
Cine
We watched the ripped MKV 3D version a few weeks ago with no issues at all.
CineMan
#12 Post by CineMan » Sun Dec 10, 2017 9:26 am
hm...is makemkv shown you the right fut ?
sometimes it is mysterious :shock:
Cine
