Question on Conversion Profile
spl147
Post by spl147 » Sat Sep 23, 2017 4:51 pm
i created a Conversion Profile to Create a DD5.1 Track from Dolby TrueHD/Atmos and Kepp the TrueHD/Atmos track. it works perfectly.
the only issue i have is with the naming of the second track before conversion:
how can i get it to automaticly say the conversion?
like this one does:
here is the profile:
<?xml version="1.0" encoding="utf-8"?>
<profile>
    <!-- profile name - TrueHD add DD5.1 -->
    <name lang="eng">TrueHD-DD</name>
    <!-- Common MKV flags -->
    <mkvSettings
        ignoreForcedSubtitlesFlag="true"
        useISO639Type2T="false"
        setFirstAudioTrackAsDefault="true"
        setFirstSubtitleTrackAsDefault="true"
        setFirstForcedSubtitleTrackAsDefault="true"
        insertFirstChapter00IfMissing="true"
    <!-- Settings overridable in preferences -->
    <profileSettings
        app_DefaultSelectionString="-sel:all,+sel:(lossless|eng),-sel:(core),-sel:(lossy),-sel:mvcvideo,=100:all,-10:favlang"
    <!-- Output formats currently supported by MakeMKV -->
    <outputSettings name="copy" outputFormat="directCopy">
        <description lang="eng">Copy track as is</description>
        <description lang="ger">Track 1:1 kopieren</description>
    </outputSettings>
    <!-- AC3 Encoding -->
    <outputSettings name="AC3-640" outputFormat="AC3">
        <description lang="eng">Save as AC3 (640kbps)</description>
      <extraArgs>-b 640k</extraArgs>
    </outputSettings>
    <!-- Dolby Digital 5.1 Surround-->
    <audioMixSettings name="DD5.1"
        outputChannelLayout="5.1"
        mix="DolbyDigital">
        <description lang="eng">Dolby Digital 5.1 Surround</description>
    </audioMixSettings>
    <!-- Default rule - copy as is -->
    <trackSettings input="default">
        <output outputSettingsName="copy"
                defaultSelection="$app_DefaultSelectionString">
        </output>
    </trackSettings>
    <!-- Add AC3 640kbps 5.1 Track to Multi Channel TrueHD and keep TrueHD Track-->
    <trackSettings input="TRUEHD-multi">
                defaultSelection="$app_DefaultSelectionString,+sel:all">
        </output>
        <output outputSettingsName="AC3-640"
                audioMix="DD5.1">
        </output>
    </trackSettings>
</profile>
spl147
Re: Question on Conversion Profile
Post by spl147 » Tue Oct 31, 2017 1:50 pm
Mike?
