UK Release of the TV Series "Legion"
ns01-2017
I get FUT errors when I try to rip this one.
Re: UK Release of the TV Series "Legion"
Did you forward the file generated to svq@makemkv.com for analysis?
Disposable9
I'm having problems with this disc as well.
I sent my dump files in a week or so ago, but I now realize I sent them to the support@makemkv.com address.
I've resent them now to svq@makemkv.com
ns01-2017
Woodstock wrote:Did you forward the file generated to svq@makemkv.com for analysis?
Looks like somebody else has just done it, but I can send mine as well if it helps to have more than one. Just a suggestion, but I would edit that FAQ entry title to include "FUT Errors" as one of the reasons for sending the log file, I read that entry as it's worded today and wasn't sure if it applied to discs generating FUT errors. Anyway, thanks in advance for taking care of this disk
FUT errors will generate a file in your MakeMKV directory (find that in Preferences->General), so if you had them, there would be a file with the disk's name found there.
It is possible that the BD+ program on different releases of a disk will be different, so I'd guess that getting files from more than one source could help Mike in getting the SVQ completed.
Disposable9
Is there any update on this one?
Thanks in advance
Thanks in advance
It is very rare that Mike will make an announcement about creating a new SVQ file for FUT errors. The test is to try ripping that title again; if you have enabled contacting the server for updates, it will just "work" when the SVQ is available.
Disposable9
I've successfully ripped these discs now and I just wanted to say a big thank you for creating the SVQ file, it's much appreciated!
