Hello together,MakeMKV does'nt find my Bluray Burner LG BP55EB40,
what is wrong? Windows shows it.
regards Thomas
LG BluRay Burner
Re: LG BluRay Burner
Does Windows show it as an optical drive?
MakeMKV asks the operating system for a list of optical drives. If the OS doesn't list any, it's rather hard for MakeMKV to know about them.
In Explorer, it should be listed in "devices with removable media".
It may fix itself with a reset of your computer, when Windows refreshes its hardware list.
Tommyworker
Hello together,
i restartet the server and no change, windows schows me the LG BD Player, but
MakeMkv do not gives me the choice to select ist. For more info's a screen snippet.
Regards Thomas
Sorry, i found the problem, starting MakeMkv as Admin fixed the problem.
Thank your for your fast help
Regards Thomas
