Unknown volum key
arnstad
Unknown volum key
Post by arnstad » Sat Oct 28, 2017 4:16 pm
Hi. I'm using MakeMKV 1.10.7 on MacOS 10.12.6.
Using an external DVD/BD player I have been able to rip a DVD (Blade Runner, Final Cut), but unable to rip any BD I have got some of them to play on VLC. So the drive works. It also appears under "storage" in the about menu.
MakeMKV does not find the external driver, but by "open files" I managed to rip the DVD. Doing the same with BD just tells me "The volume key is unknown for this disc - video can't be decrypted". I have tried a couple of different BD, but same error on all of them.
Debug log started at Sat Oct 28 16:05:43 2017 , written by MakeMKV v1.10.7 darwin(x64-release)
001005:0000 MakeMKV v1.10.7 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/fredrikarnstad/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at \[a8,*G)g#}~ZU:121263659
001003:0020 DEBUG: Code 117637427 at +pkY$;Vn"|#C?V49:121263567
001003:0020 DEBUG: Code 0 at +pkY$;Vn"|#C?V49:213131502
001003:0020 DEBUG: Code 0 at gc'PfN7::hLe[}(:213131525
005042:0000 The program can't find any usable optical drives.
003006:0000 Opening files on harddrive at /Volumes/THE_PHANTOM_MENACE
DEBUG: Code 2147483648 at C4:LH)oM,kLRJPh6:121265315
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at 5=p2aTp8u1jAn;p::29396046
001003:0020 DEBUG: Code 0 at 5=p2aTp8u1jAn;p::213134009
Re: Unknown volum key
Post by Woodstock » Sat Oct 28, 2017 5:46 pm
Are you copying the disks to your hard drive, or are they still on the optical media?
MakeMKV is asking for a list of optical drives, and is being told there are none. When it finds where the disk is, it does not know where the disk information that tells it which key to use is located. So it has to fall back to being told what the volume key is.
Try this - do NOT insert the disk in the drive until after MakeMKV starts, to see if it finds the optical drive. It may be that the operating system is mounting the disk. It's not supposed to, but weirder things can happen.
arnstad
Post by arnstad » Sat Oct 28, 2017 6:23 pm
Woodstock wrote:Try this - do NOT insert the disk in the drive until after MakeMKV starts
The system recognizes the optical drive ( > about > storage), but MakeMKV still can't find it. Finder won't show the empty drive though.
Woodstock wrote:Are you copying the disks to your hard drive, or are they still on the optical media?
I'm still on the optical media, I have tried opening all the files MakeMKV allows me to open (BDMV, *.inf)
Post by Woodstock » Sat Oct 28, 2017 8:02 pm
MakeMKV gets its list of optical drives from the operating system. Hopefully someone with MacOS experience can chime in here with why MacOS would not report an optical drive.
Does MakeMKV give the same error if you insert a DVD instead of a BD in the drive? If not, I would think something is "mounting" the BD for you, so the optical drive isn't treated as one.
arnstad
Post by arnstad » Sun Oct 29, 2017 9:35 am
Woodstock wrote:Does MakeMKV give the same error if you insert a DVD instead of a BD in the drive?
MakeMKV won't recognize the optical drive even with a DVD inside, the very DVD I ripped earlier today. I still had to "open files" and select the "VIDEO_TS.IFO" file to open and rip the DVD. Which did work, I have opened and played back the MKV file. But now I get a "failed to open disc" error on the DVD.
Debug log started at Sun Oct 29 09:27:20 2017 , written by MakeMKV v1.10.7 darwin(x64-release)
003006:0000 Opening files on harddrive at /Volumes/BLADE_RUNNER_FINAL_CUT/VIDEO_TS
003002:0000 Calculated BUP offset for VTS #0 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #1 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #2 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #3 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #4 does not match one in IFO header.
001003:0020 DEBUG: Code 1073741837 at u6=6T1/d(}VaUvF|:29393953
003028:0000 Title #1 was added (15 cell(s), 0:45:58)
003025:0000 Title #2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=2 pgcn=2 hash=C6926B6265772275
003025:0000 Title #5 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8 has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
002003:0000 Error 'Posix error - Permission denied' occurred while reading '/Volumes/BLADE_RUNNER_FINAL_CUT/VIDEO_TS/VTS_01_2.VOB' at offset '2048'
DEBUG: Code 1073741837 at He'h'v`|Net3Q7\H,@:213130904
001003:0020 DEBUG: Code 1073741837 at He'h'v`|Net3Q7\H,@:121262969
001003:0020 DEBUG: Code 1 at 7+L'N//}C9&X~x4q:29394390
001003:0020 DEBUG: Code 0 at HWaH#A^H7SJW!G]:121271180
001003:0020 DEBUG: Code 0 at k\ZJm?&2rEqN`&:213134883
Encountered 36 unclassified errors
error=0x4000000D count=36 name=Posix error - Permission denied
Post by Woodstock » Sun Oct 29, 2017 2:02 pm
Then, when was the last time you reset your Mac? And is MakeMKV running with administrative privileges, so that it can talk directly to the hardware?
Decrypting DVDs is not as complex as BDs, from what I've been reading. Everything you need to do so can be included in an ISO of the DVD; it is in the data the computer sees. There is region locking, which the drive enforces, but if the drive allows you to read the data, that isn't a big issue.
Not so with a BD; there are parts of the "generic" decryption process that require access to the physical disk, OR possession of the "volume key" that the physical access allows. An ISO or mounted file system doesn't allow access to that exchange of disk data, which is why MakeMKV can't discover the volume key on its own.
arnstad
Post by arnstad » Fri Nov 03, 2017 8:14 am
Maybe its the optical drive. I tried the same drive with an old windows laptop, running as admin, with MakeMKV 1.10.7. The drive appears in "My Computer" but not in MakeMKV.
