The Big Sick
KENSAI
Re: The Big Sick
Post by KENSAI »
Woodstock wrote:But, if you have the Java Runtime Environment installed (from java.com), MakeMKV will make an educated guess at the right title, and move it to the top of the list
I wish this worked more often - I was excited when I finally got it working on my iMac, but with quite a few movies it fails to flag anything at all (such as The Big Sick). This feature seems to work better on Windows than Mac.
asr101
Re: The Big Sick
Post by asr101 »
Woodstock wrote:But, if you have the Java Runtime Environment installed (from java.com), MakeMKV will make an educated guess at the right title, and move it to the top of the list.
I only see this work occasionally, because I avoid buying titles from Lionsgate.
What is the procedure to submit information to MakeMKV when the JAVA does not work?
Re: The Big Sick
http://www.makemkv.com/forum2/viewtopic.php?f=8&t=14330
WAYFLIX
Re: The Big Sick
Post by WAYFLIX »
mitchell_pgh wrote:
WAYFLIX wrote:Thanks. Awaiting confirmation!
Same here... fingers crossed.
Just watched it. Confirmed!
asr101
Re: The Big Sick
Post by asr101 »
I have submitted the back up file. Hope it helps.
wylde31
Re: The Big Sick
Post by wylde31 »
salamonka wrote:I just got PowerDVD. 00920 is what you want.
Title information
Name: The Big Sick (2017) (English)
Source file name: 00920.mpls
Duration: 2:00:24
Chapters count: 16
Segment count: 11
Segment map: 505,506,502,503,510,501,500,508,509,504,507
File name: The_Big_Sick_(2017)_t344.mkv
Where do you find this information in PowerDVD? Apologies in advance for the noob question.
wylde31
Re: The Big Sick
Post by wylde31 »
Nevermind, I found the right forum post.
jandjfrench
Re: The Big Sick
Post by jandjfrench »
My disc does not have a "00920.mpls". I arbitrarily selected "00058.mpls" and surprisingly the resulting mkv shows everything in the proper order.
MZAdotcom
RE: The Big Sick
Post by MZAdotcom »
Title information
Duration: 2:00:24
Chapters count: 16
Segment count: 11
Just watched this flick and can confirm that this info is correct for the Netflix rental version. The only detail that was different was in the file name: The_Big_Sick_(2017)_t345.mkv, NOT The_Big_Sick_(2017)_t344.mkv.
Cheers.
@HTPC: Intel NUC HTPC [BOXDN2820FYKH0] | Plextor 128GB SIII SSD | G.SKILL 8GB DDR3 1333 RAM | Win 10 Pro | SAMSUNG 55" LED HDTV | Harman/Kardon 5.1 AV Receiver [AVR 1565] | Dolby TrueHD | DTS-MA HD | Polk Audio 5.1 Home Theater System w/10" SW
rogodeter
Re: The Big Sick
Post by rogodeter »
hvnphoto wrote:
marianiode wrote:Anyone know what the right file name for this tittle is? Thanks...
For the Retail Version, it is 00544.MPLS.
Do you have the track/chapter details so I can compare that to my distribution. i don't have a 920 so this might be the right one.
yorgo
Re: The Big Sick
Post by yorgo »
Check/compare to the segment map posted by salamonka: http://www.makemkv.com/forum2/viewtopic ... 594#p57486
rogodeter
Re: The Big Sick
Post by rogodeter »
yorgo wrote:Check/compare to the segment map posted by salamonka: http://www.makemkv.com/forum2/viewtopic ... 594#p57486
Thanks, but I looked through all the title (albeit manually scanning them visually) but I couldn't find a single title in the hundreds presented by MakeMKV, that has 506 in the second index of the list. I guess with different distributions (retail, netflix, redbox) they even change the numbers/names associated with each title. Is that right?
rogodeter
Re: The Big Sick
Post by rogodeter »
I just re-verified it -- there's not a single file with 506 in position 2 on the segment map. I found one title with 506 in it and it was the only segment.
Title information
Name: The Big Sick (English)
Source file name: 00043.mpls(3)
Duration: 0:26:15
Chapters count: 4
Segment count: 1
Segment map: 506
File name: The_Big_Sick_t16.mkv
I'm on Linux and don't know of any other application I can use to determine the correct file.
pimpinonline
Re: The Big Sick
Post by pimpinonline »
Title information
Duration: 2:00:24
Chapters count: 16
Segment count: 11
Thank you!
Drilian
Re: The Big Sick
Post by Drilian »
jandjfrench wrote:My disc does not have a "00920.mpls". I arbitrarily selected "00058.mpls" and surprisingly the resulting mkv shows everything in the proper order.
I can verify that this worked for my disk, too (thanks, because I definitely picked some wrong ones before I noticed this one).
For reference it's:
Name: The Big Sick
Source file name: 00058.mpls
Duration: 2:00:24
Chapters count: 16
Segment count: 11
Segment map: 502,505,510,509,503,500,504,501,507,508,506
