Does MakeMKV support Atmos Dolby Digital Plus Streams?
Dazkine
#1 Post by Dazkine » Mon Oct 16, 2017 2:56 pm
I got a Disk with DD+ Atmos Track. TrueHD Atmos works and you can see what MMKV recognize Atmos, but with DD+ there it says no Atmos.
Any clues?
Meister_Proper
Re: Does MakeMKV support Atmos Dolby Digital Plus Streams?
#2 Post by Meister_Proper » Wed Oct 18, 2017 4:36 pm
Did you try to remux it anyway? What does mediainfo say?
Dazkine
#3 Post by Dazkine » Thu Oct 19, 2017 6:53 pm
Audio #1
Format : E-AC-3
Format/Info : Enhanced Audio Coding 3
Format profile : E-AC-3+Atmos / E-AC-3
Format settings, Endianness : Big
Codec ID : A_EAC3
Duration : 1 h 50 min
Bit rate mode : Constant
Bit rate : 500 b/s
Channel(s) : 8 channels
Channel(s)_Original : 11 objects / 6 channels
Channel positions : 11 objects / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 187.500 FPS (256 SPF)
Compression mode : Lossy
Stream size : 907 MiB (4%)
Title : Surround 7.1
Language : German
Service kind : Complete Main
Default : Yes
Forced : No
That is what Mediainfo says. But MakeMKV does not recognize the Atmos informations
spl147
#4 Post by spl147 » Thu Oct 26, 2017 9:12 pm
Dazkine wrote:
Audio #1
Format : E-AC-3
Codec ID : A_EAC3
Bit rate : 500 b/s
Language : German
Default : Yes
Forced : No
That is Not a Atmos track. Atmos is a Extension of TrueHD, AC3 is the Core of Dolby Digital.
ATMOS ia LossLess
here is a Atmos Track
Audio #1
Format                                   : TrueHD
Format profile                           : TrueHD+Atmos / TrueHD
Duration                                 : 2h 24mn
Bit rate                                 : 4 641 Kbps
Maximum bit rate                         : 7 500 Kbps
Channel(s)                               : Object Based / 8 channels
Channel positions                        : Object Based / Front: L C R, Side: L R, Back: L R, LFE
Sampling rate                            :  / 48.0 KHz
Frame rate                               : 1 200.000 fps (40 SPF)
Stream size                              : 4.68 GiB (15%)
Dazkine
#5 Post by Dazkine » Fri Oct 27, 2017 8:15 pm
Nope that isn true. Atmos works with DD+ as well...
trumpet205
#6 Post by trumpet205 » Sun Oct 29, 2017 4:14 pm
Dazkine wrote:I got a Disk with DD+ Atmos Track. TrueHD Atmos works and you can see what MMKV recognize Atmos, but with DD+ there it says no Atmos.
Any clues?
It does not matter what MakeMKV says. What matters is if the receiver picks up Atmos. Have you actually test it on the receiver?
Atmos is just metadata. It does not need explicit support from MakeMKV. In fact your MediaInfo shows that it is indeed an Atmos track (DD+ Atmos).
spl147 wrote:That is Not a Atmos track. Atmos is a Extension of TrueHD, AC3 is the Core of Dolby Digital.
ATMOS ia LossLess
You are wrong here. Atmos can be applied to E-AC3 as well.
In fact, Dolby is providing sample files for people to test it on their receiver.
https://www.dolby.com/us/en/guide/test-tones.html
General
Complete name                  : E:\dolby-test-tones_5_1_2.mp4
Format                         : MPEG-4
Format profile                 : Base Media / Version 2
Codec ID                       : mp42 (mp42/dby1/isom)
File size                      : 116 MiB
Duration                       : 8 min 23 s
Overall bit rate               : 1 926 kb/s
Encoded date                   : UTC 2017-01-23 18:50:03
Tagged date                    : UTC 2017-01-23 18:50:03
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : Main@L4.1
Format settings, CABAC         : Yes
Format settings, RefFrames     : 3 frames
Format settings, GOP           : M=4, N=24
Codec ID                       : avc1
Codec ID/Info                  : Advanced Video Coding
Duration                       : 8 min 20 s
Bit rate                       : 1 485 kb/s
Width                          : 1 920 pixels
Height                         : 1 080 pixels
Display aspect ratio           : 16:9
Frame rate mode                : Constant
Frame rate                     : 24.000 FPS
Standard                       : NTSC
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Bits/(Pixel*Frame)             : 0.030
Stream size                    : 88.6 MiB (77%)
Default                        : Yes
Alternate group                : 1
Color range                    : Limited
Color primaries                : BT.709
Transfer characteristics       : BT.709
Matrix coefficients            : BT.709
Audio
Format                         : E-AC-3
Codec ID                       : ec-3
Bit rate                       : 448 kb/s
Channel(s)                     : 15 objects / 6 channels
Channel positions              : 15 objects / Front: L C R, Side: L R, LFE
Bit depth                      : 16 bits
Stream size                    : 26.9 MiB (23%)
Default                        : Yes
Alternate group                : 2
Atmos is just metadata. There is nothing lossless or lossy about it. It can be used on DD+, not just TrueHD.
