Error backing up _The Good, the Bad, and the Ugly_
ludinom
#1 Post by ludinom » Thu Oct 26, 2017 5:16 pm
I am trying to back up a Blu-Ray of The Good, the Bad, and the Ugly using my Pioneer Slim External Blu Ray Writer BDR-XD05B, with the latest firmware:
Current Revision>> PIONEER BD-RW   BDR-XD05 3.10  17/06/22
Current Signature = ID34
FW is already latest.
I got the following messages in the MakeMKV window:
MakeMKV v1.10.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\mnl/MakeMKV_log.txt
Backing up disc into folder "C:\Users\mnl\Videos\Movies/backup/The Good the Bad and the Ugly"
Downloading latest SVQ(s) to C:\Users\mnl/.MakeMKV ...
Loaded 98 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/generic.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/01559.m2ts' at offset '27922200576'
DEBUG: Code 0 at .Wml\c8.4lB]1<3d^3^:213134354
DEBUG: Code 0 at .Wml\c8.4lB]1<3d^3^:29397564
DEBUG: Code 0 at "HDl:v;1w])uzw/XDzU1:213133319
Backup failed
I have included the full log file below.
I looked closely at the disc and the surface looks very clean.
Any suggestions?
If this really is uncorrectable, can it just be skipped over (with corresponding possible glitches during playback), with the backup then allowed to proceed, resulting in a usable if imperfect backup?
Thank you for any help.
Regards,
Ludinom
Log file:
Debug log started at Thu Oct 26 15:45:18 2017 , written by MakeMKV v1.10.7 win(x64-release)
Using 1048320KB for read cache.
001005:0000 MakeMKV v1.10.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\mnl/MakeMKV_log.txt
005072:0000 Backing up disc into folder "C:\Users\mnl\Videos\Movies/backup/The Good the Bad and the Ugly"
DEBUG: Code 2147483648 at nOtg/d[{almPI{.I:121265315
DAFD=PAAAADAAAAEABDQkEGwEBAQ==
DCE=2lmXlE+zhnEb13kv/5L0PHpOsjm7nxwdqkO2TfyubDQYpABgYXpKDsmcX7LiQvOSe7yT0mHHQCR/ywKtHgV4NoCTTEEZGKYrFnYfmsSpUkxu9m9DcmGT6xwEK1AcJASvUAqA4LtyD5Vjd++zoXSJkfNXfI0ooLqu8A==
DCE=rc9gYE1pZljcHb+teaC7OUCp2pp20eVwF3dj/qJjV70AbCCxHtL8+LVYdjsd11ZjjdJ/U8VGAOEgAsfexG13W+ElF29ZBu4/6wi5DzGh0JXB6PKHvk2CcbUSpCsdAEsW9h4gP7WVC1kJRMbClG8PcFSElOziyKNHcQ==
003338:0000 Downloading latest SVQ(s) to C:\Users\mnl/.MakeMKV ...
003317:0000 Loaded 98 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/generic.svq
SVQ: generic005 builtin/generic.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
001003:0020 DEBUG: Code 3221225628 at sJjl>=@SLUfi_,-z(KiJ3EID_:213131617
001003:0020 DEBUG: Code 3221225628 at :?q+E$ub;upg;vX*:29393953
001003:0020 DEBUG: Code 100864261 at 's+Ay19T1\mWh,AL:121269731
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/01559.m2ts' at offset '27922200576'
001003:0020 DEBUG: Code 0 at .Wml\c8.4lB]1<3d^3^:213134354
001003:0020 DEBUG: Code 0 at .Wml\c8.4lB]1<3d^3^:29397564
001003:0020 DEBUG: Code 0 at "HDl:v;1w])uzw/XDzU1:213133319
005069:0080 Backup failed
005080:0204 Backup failed.
Application exited at Thu Oct 26 16:55:11 2017
Re: Error backing up _The Good, the Bad, and the Ugly_
#2 Post by Woodstock » Thu Oct 26, 2017 5:33 pm
MakeMKV is not going to skip over unreadable sections of the disk; It's goal is a "bit perfect copy" of the video.
Have you tried cleaning the disk? Even if new, the most frequent "fix" for unreadable sectors is cleaning.
Also, if you do not need to maintain the BD menu structure, using the "Open" and "Save" will work even if some files are unreadable. The backup fails if ANY file has a problem, but save-to-MKV only fails only for the file(s) that have unreadable parts.
