War for the Planet of the Apes - no FUTs
dmillionz
The dump file has been sent via email.
dmillionz
Re: War for the Planet of the Apes - no FUTs
Mike,
When is the FUT issue going to be corrected?
dmillionz
Maybe I'm missing something. Is there a reason my post and email are being ignored? Has this issue been addressed without my knowledge? I saw another post from someone else regarding this FUT issue that was not responded to as well.
yorgo
I don't think your post is being ignored, it's simply that no one here, save Mike, can provide an exact answer. Precedent is that it may take a day or two for a new disc's copy protection to be defeated, or it may take several weeks. The way one usually finds out is that the disc suddenly no longer has the "no FUTs" problem and can be ripped. I suggest trying to rip the disc every day until it works...and having patience until then.
Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
Damundai
Finally fixed!
dmillionz
I see. Understood.yorgo wrote:I don't think your post is being ignored, it's simply that no one here, save Mike, can provide an exact answer. Precedent is that it may take a day or two for a new disc's copy protection to be defeated, or it may take several weeks. The way one usually finds out is that the disc suddenly no longer has the "no FUTs" problem and can be ripped. I suggest trying to rip the disc every day until it works...and having patience until then.
dmillionz
Not fixed here. Still getting the FUT notice. The Dark Tower is fine though.Damundai wrote:Finally fixed!
dmillionz
FWIW, I should note that mine is the retail 3D version of the movie from Amazon. Based on another user's post, I assume the standard blu-ray version is working now but the 3D blu-ray is saying no FUT. I will be sure to put 3D in the title in the future in case this helps clarify things if the versions are different. I tried to update the title but couldn't find a place to do so.
yorgo
Just to confirm, you are on 1.10.7, correct?
dmillionz
Correct. On Windows 10 Pro.yorgo wrote:Just to confirm, you are on 1.10.7, correct?
bradleyrealtor
Mike,
Please see separate topic - on 3d version, thanks.
