UK Release of the TV Series "Legion"
ns01-2017
#1 Post by ns01-2017 » Thu Oct 19, 2017 8:57 am
I get FUT errors when I try to rip this one.
Re: UK Release of the TV Series "Legion"
#2 Post by Woodstock » Thu Oct 19, 2017 1:23 pm
Did you forward the file generated to svq@makemkv.com for analysis?
Disposable9
#3 Post by Disposable9 » Thu Oct 19, 2017 8:04 pm
I'm having problems with this disc as well.
I sent my dump files in a week or so ago, but I now realize I sent them to the support@makemkv.com address.
I've resent them now to svq@makemkv.com
ns01-2017
#4 Post by ns01-2017 » Fri Oct 20, 2017 7:41 am
Woodstock wrote:Did you forward the file generated to svq@makemkv.com for analysis?
Looks like somebody else has just done it, but I can send mine as well if it helps to have more than one. Just a suggestion, but I would edit that FAQ entry title to include "FUT Errors" as one of the reasons for sending the log file, I read that entry as it's worded today and wasn't sure if it applied to discs generating FUT errors. Anyway, thanks in advance for taking care of this disk
#5 Post by Woodstock » Fri Oct 20, 2017 2:49 pm
FUT errors will generate a file in your MakeMKV directory (find that in Preferences->General), so if you had them, there would be a file with the disk's name found there.
It is possible that the BD+ program on different releases of a disk will be different, so I'd guess that getting files from more than one source could help Mike in getting the SVQ completed.
Disposable9
#6 Post by Disposable9 » Mon Oct 30, 2017 9:12 pm
Is there any update on this one?
Thanks in advance :)
#7 Post by Woodstock » Mon Oct 30, 2017 9:38 pm
It is very rare that Mike will make an announcement about creating a new SVQ file for FUT errors. The test is to try ripping that title again; if you have enabled contacting the server for updates, it will just "work" when the SVQ is available.
Disposable9
#8 Post by Disposable9 » Tue Nov 07, 2017 8:30 pm
I've successfully ripped these discs now and I just wanted to say a big thank you for creating the SVQ file, it's much appreciated!
Cheers :)
