An American Werewolf in Paris Blu Ray .... AACS Issues?
heathen2559
Re: An American Werewolf in Paris Blu Ray .... AACS Issues?
Post by heathen2559 »
Any info on the status of this please?
yorgo
Post by yorgo »
Please post the entire error report, there should be more than just the two lines. Also, please post the error log for An American Werewolf in Paris, not Miami Vice. Are you able to rip any other BD's?
heathen2559
yorgo wrote:Please post the entire error report, there should be more than just the two lines. Also, please post the error log for An American Werewolf in Paris, not Miami Vice. Are you able to rip any other BD's?
I don't mind sending in anything, but if you look at the beginning of the thread, and follow through, you will notice that I've already sent info for An American Werewolf in Paris (Why oh why can't people read threads anymore?).
Also, to date, it's the only disc that I can not rip.
yorgo
Post by yorgo »
You are posting only 2 lines of the error. What has been requested, more than once, is the entirety of the disc/error report, not just the final error message. As an example of what I mean (no errors here but hopefully this helps, make sure debug logging is enabled):
MakeMKV v1.10.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\XXXXXXX/MakeMKV_log.txt
AACS directory not present, assuming unencrypted disc
DEBUG: Code 0 at {X|&/mCX c9M~[)c:121262325
File 00001.mpls was added as title #0
File 00102.mpls was added as title #1
File 00095.mpls was added as title #2
File 00096.mpls was added as title #3
File 00010.mpls was added as title #4
File 00011.mpls was added as title #5
File 00034.mpls was added as title #6
File 00035.mpls was added as title #7
File 00036.mpls was added as title #8
File 00037.mpls was added as title #9
File 00038.mpls was added as title #10
File 00039.mpls was added as title #11
File 00040.mpls was added as title #12
File 00041.mpls was added as title #13
File 00042.mpls was added as title #14
File 00044.mpls was added as title #15
File 00045.mpls was added as title #16
File 00046.mpls was added as title #17
File 00047.mpls was added as title #18
File 00048.mpls was added as title #19
File 00049.mpls was added as title #20
File 00050.mpls was added as title #21
File 00051.mpls was added as title #22
Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Saving 55 titles into directory B:/BackUps/YYYYYYYYYYYYYYY
Forced subtitles track #4 turned out to be empty and was removed from output file
Forced subtitles track #8 turned out to be empty and was removed from output file
Forced subtitles track #3 turned out to be empty and was removed from output file
55 titles saved
I've deleted a few items to keep it short but this is a complete report from de-encryption to completion of rip. Please post the report for your disc. Without that, I don't believe anyone on the forum can help.
heathen2559
ebug log started at Mon Oct 23 00:11:41 2017 , written by MakeMKV v1.10.7 darwin(x64-release)
001005:0000 MakeMKV v1.10.7 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/xxxx/MakeMKV_log.txt
002014:0000 Optical drive "BD-RE TSSTcorp BDDVDW SE-506BB TS00" opened in DASPI v1.5 mode.
DEBUG: Code 2147483648 at C4:LH)oM,kLRJPh6:121265315
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=Nzb4o3i+Urm8D2Qy2opvbnaPqlVJHXLCpbMaNnzI182cHUUwxtGTvECWP8prvEBGu8Ff3+GODmY9Y1UsL6lIwwf5+rEAKd++jvMIhgPIn7fsSTmLFh/yqFsf+kC5F2CPBJkasjdlxeKcPPmAjoAZJT5V+eCx4MIm6A==
002004:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while issuing SCSI command AD010..080002400 to device 'DASPI:IODASPIService:469bb16baec1a433:'
DEBUG: Code 0 at +w/0ic!t6ddfV&t^P:213130306
001003:0020 DEBUG: Code 0 at /6.TjK(%"SLucfJ!I":29396345
001003:0020 DEBUG: Code 0 at /6.TjK(%"SLucfJ!I":121262647
DCE=qyG3KO5157QnOleqvsYdC983rhEnNRLosQen7x4FLM6RN3s5zuDQbtgj2c11STlJCgvle41u+tyJn2UVvQbwaPuhzT4N48slZxXGXr/4yqrjTvXfhn3O4ReRpklGMyM6QV6p0pQXh6ys6R+2ERABu29FE7RkzLxeRA==
001003:0020 DEBUG: Code 1 at /6.TjK(%"SLucfJ!I":121262647
DCE=WqhWdr0FpdGtfd4hBzfuEU7Nk865DVU/927j5U194JvDOLEH2BCFdwVoPkN/r0Si7CvJD5BgI26Y12wW5Rt7GwZb85/3E8D6Ee6Wo+jPQtLkWwiLg5zEWDJ0yeS8zanPwVz7eeSnWIEljSCxelE3SGVavnHhjDJTiQ==
001003:0020 DEBUG: Code 2 at /6.TjK(%"SLucfJ!I":121262647
DCE=xDlTH969IPVS1xeaYYQoGNVXk98Hrcx5ZmCNeIvsbgfp8ZxxqrOD9kfrBhyfS7w1OEDFsrq3qNEpzS7Yjaxp+pWutnGmYhZISzY/HwRSJsikyA/vHfanqHSR5iC94IjMElmFzYJVqvTZcHjJxRE9fVYi7ykFXQDoGQ==
001003:0020 DEBUG: Code 3 at /6.TjK(%"SLucfJ!I":121262647
DCE=yFWNdkAeIeGkuFnLekCVGSTxYgPMxes6pwRqSG0KzsfHoTH1Z+p7qXNCjq57yEcphcOxulmu55uri0rVK3IUIUF6lvWdqfQaT9/wDKtWoA7MmdtR1tKkhAN7DJDn6OhMJUMZybhPp5iavmaCpzxm5VaTKESfwLHnaw==
001003:0020 DEBUG: Code 4 at /6.TjK(%"SLucfJ!I":121262647
DCE=11aFp9QdUT5qCwPSnVRb5BlLLfh/GcXfO/d0ror0osgOZ6qAWrJ8QlaWILL958RDKXQl1dCB4nVHNuoWuJtaUHNmC0paeRkJsXycV1iR/xDpLRjKjTJccN6z4qGcnBpvDppv989PUrLm8dtE99MSMuQGb6am7//u7w==
DCE=p1AMgCef/KOlip6uNWciEOBo5Xd4XCj/K66lO1CsvliNPM+aoiFNLHQipSM/3zezJd7CZYoiMrgOUHmOE2SnU76myDeN3aW6Qe4vfeCOhkNnzL/0MVbgaB5s3M+M2qcuMYi2wFu16o58gzsyMugTnxsGTJsduf0PXg==
DCE=LyXSVlDQFkCtfstwdmMJoS+0eo+zOwigCoCVMsuhv9ceE4Aaa5QXxTXFaaXsjunfyZlrQPgibGjfaJ6BVfI1rhA0Cwout8GHw+PKTQKHNZoochVLyZzxmOX+r/zmaOjXT8s2LzRfyILNbzi3N2gBahDpk8z5Tyn0uw==
DCE=ER869XRO5pxss/JKqh7E5g4rHfCKnJO51ibV+KV8Yb3STxXsgPOtkd6t6pN8VrcgcmhktSQCitPFgrH74LX7g8jVQC2OMFle/oV+uPAiLQvvtLZvlT2njN8GKb1jv8TzIIG22LXFjvVwRZ+UoqfHUphXXNyPKnB03Q==
DCE=d33P4x3ksJKaGAQDrNbmFKAecMxwA4kPRsTd62lacZtgixiNeZ+0jp/yKkDDBOKNzMaKoov7aNmx44iSFHiA6OXha2lWxR0WhOabKUAMK/x2o95oeXgqAgNgOSYyonkpVvTCU8U8fcyJBu6sYrPrparaDekkNiQrJA==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00F07E82D0BB9263CDEB4E295E2812944AA to device 'DASPI:IODASPIService:469bb16baec1a433:'
001003:0020 DEBUG: Code 0 at +w/0ic!t6ddfV&t^P:213130766
001003:0020 DEBUG: Code 0 at /6.TjK(%"SLucfJ!I":29395195
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..064F573EA8EC5FC929E7ACB17D10B54AF4D to device 'DASPI:IODASPIService:469bb16baec1a433:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0EADC19C83C20FB4AABD4B6D5C3F0934505 to device 'DASPI:IODASPIService:469bb16baec1a433:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0AF503673114202153D646E2985C1DD1B1D to device 'DASPI:IODASPIService:469bb16baec1a433:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E905CC23808319D1B13FAD268DDBF0166C to device 'DASPI:IODASPIService:469bb16baec1a433:'
DCE=cPSoBobMX2iErUjqKVAOJv29Zbk+SYq/vsnClSDNezZeE9ZAwAoXAMi9aodvB2ZfqSU1eiGP+LN14xnFCap2uppMfNwLSdG77JCkdbFquCa7iuT/pp4RulsFRNQex20ESyPe7qNYX7O4KptVIpDJEkIzo90JeepM4A==
DCE=XIM0xsuReNf14nZus9W1xucHtFUz4SOb1bBNaoSyXzU+MrdTrpwoy0Q6KApIWSdd7MyalGym6IOQFHNWvNtVFp30zeL1BVv98bL/u25ssLxyYhASuydp1SYIzTRjrp8mZCUy05CcC/k8U/GG26Sk8jBxFBBk9vr3xw==
DCE=NJtEUSaRTkVWhISzhE2jTLdE/wucjjXbeK7xO64igQjakBskDJKr5Icqc1ntJIuc0ta2ttcXd0/5hZx5jLF28BylhxBQzj87nDrvBaJ9CZb6BgB92e4v9dhCdwKYmuCalhZiqAUGR3L3Fla2hosDWP8L8B966ztRVA==
DCE=fVQLibGjCxfFxDX4xYNSN8wjAO/oWP/wqCMR7WUF/nHhkdCaHCY9MdPZIL2OIujVXxa4meO9mHyd9Ms2i1AF48wEXTQFiodV28x7cqeerInO0dvU4eaScRhYfpuB7BmmdYBvk/pYKs2JxFG+q1gRza3sFR/ljVQzbw==
DCE=dlFGiOc0CSf0IXUyGPFtTjWbEpeEdHaUZtV1V2OYHVL/skKU/WF1LZb1ulGzdF8jKJ0OHQdiNlk0LhLmb+ic5Cx7U0z/NLSUfTb59/WiOGDkK2ujv7bIO/3FM5bJ8zLdeSm4i1XzwCcHhyaaDyVySGRgOuGfXU0Hiw==
DCE=Vn8CmO3gTDc7x2JXSwe2Xzi8JlE2sHu3ZNh/E5vwCzN9z1uf9XMPqw9bXieKIz/oa8wfMIfVf04W3iEBnxBbhfZScwir0mWQFWo0l1hc0QYrN5QeWfoDrD9KnL7piH9vB+0CFtCvKOQyTdnPB++FPw595Gs7LjNsiQ==
DCE=tR+kbbwAyMe+256nTwCi24XH77HBMo4U9O92pJ98J8G0wcNLw7HwWRfqrVLrHTsSflwtj8BDXg77IOZgnJU6umYp9Juv2VV8RdQiqUMxwpnEinCW2w0cgzDzJ3KXjQeX9oIlCAuCaLH6lPoib4aq6e7/eeaLfU/NRg==
DCE=tptYJ81V4MvKvGMljPQfvYHBtmXCEmcbHDoJIxI0EHQhdya2/Eg2c+4mpmM7fJe95xxvj+4LDxRBSLfbxpwR9ptQbWvCksrIYw9jmpO6mhqktWQ1C6uTpMmOrAKXY/w+Sa0CD/4ln94qxOxZyeQWVjl0xV6cvf2WXQ==
DCE=b8KTV9cGPgukhYPy3cZ8FvZb1mjCcmVk16Cao81TCvYCy3XGKUqjhqbvEC5YoCiCsZbNqbghcxA9CPN4AyGNRdUTQ2zJaAoDxrdz4B9IFZLYWwxV8FvkJJQxm9uNFfGPEPXFyC1mv/xMIfGsD+U/rbOgIhFpgR+w6g==
DCE=zoCh1Jc3YHc+QTRFBSnkH3FUHB74J0xBnAryp/RhfGb0m5SH0VwOSWgnHnaf+UfLnahQChMgRRlxJdJDj/NXtgHCeSvkmG9z8Zza9ywZUcYD1oohAyyHz5uN7UlZkLpuhYuCZhWvLusLJza6jWftq1tkrcLCEBD5Ng==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0128A5B79E84A626FB30199EAF8400C357E to device 'DASPI:IODASPIService:469bb16baec1a433:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'DASPI:IODASPIService:469bb16baec1a433:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05C6D6BCCB0751063F8ABC91AD4435EF092 to device 'DASPI:IODASPIService:469bb16baec1a433:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0F7EFB2D02FD7505A06B58D43854815170E to device 'DASPI:IODASPIService:469bb16baec1a433:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..036F53893E3B713997F6198D46E379BC41B to device 'DASPI:IODASPIService:469bb16baec1a433:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B56B1681F8DA0A3163B69161C18FB8BBA5 to device 'DASPI:IODASPIService:469bb16baec1a433:'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003341:0000 Highest AACS version is v62 , MKB saved as /Users/bwaits/.MakeMKV/MKB_v62_An_American_Werewolf_in_Paris.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at 5=p2aTp8u1jAn;p::29396046
001003:0020 DEBUG: Code 0 at 5=p2aTp8u1jAn;p::213134009
yorgo
Post by yorgo »
Now this is helpful.
If you've successfully ripped other blu-ray discs especially ones which have AACSv62 protection, on the same drive in the same computer, using MakeMKV 1.10.7, then the issue lies in the specific disc you own; it's dirty, damaged, or has mastering or pressing errors preventing a rip (which is what is generating the "Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' " message). In fact, it may be that the errors are occurring in a part of the disc that needs to be read first in order for MakeMKV to de-encrypt, therefore the "Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' " message following the other error message.
I'm assuming you've cleaned the disc (water and mild soap, soft cloth to dry) and there are no visible scratches/cracks -- you have not stated the condition of the disc or that you've cleaned -- therefore the recommendation is to replace given what your error report shows.
I hope you now see the need to forward complete information, will help prevent the kind of delay you've been experiencing.
heathen2559
Actually, this is a brand new disc. This was happening from the moment I took the shrinkwrap off of it. No fingerprints, no signs of rot, and nothing that I can see with respect to scratches, smudges, or any other internal strife that can be visually seen.
I've become more suspicious of disk contamination on new, unopened disks over the last two years, especially if they've been sitting on the retail shelf for very long. The industry has started using some chemicals in the packaging that are transferring to the disks. I posted a picture of it in this topic: http://makemkv.com/forum2/viewtopic.php?f=8&t=15055
The disk looks clean to humans, but the laser gets scattered by the film. Fortunately, it seems to be water soluble, so it cleans up easily.
yorgo
Post by yorgo »
heathen2559 wrote:Actually, this is a brand new disc. This was happening from the moment I took the shrinkwrap off of it. No fingerprints, no signs of rot, and nothing that I can see with respect to scratches, smudges, or any other internal strife that can be visually seen.
Be that as it may, the disc may still have errors that are not visible, errors created during pressing or mastering. I've come across many discs that were brand new or purchased used blemish-free that would not rip on 2 different drives. After replacing, they ripped with no problem (most times, though I've also had to replace discs more than once). Again, recommendation is to replace the disc.
heathen2559
Woodstock wrote:I've become more suspicious of disk contamination on new, unopened disks over the last two years, especially if they've been sitting on the retail shelf for very long. The industry has started using some chemicals in the packaging that are transferring to the disks. I posted a picture of it in this topic: http://makemkv.com/forum2/viewtopic.php?f=8&t=15055
In this case, this is a brand newly released disc that just was released, so it hasn't been sitting on the shelf long. I will try your cleaning by water and see if that has any positive effect.
heathen2559
Sadly, cleaning the disc did not help.
Funodav
Post by Funodav »
I tried to open the Akira (Dybex release) bluray disc and it won't decrypt it : it locked to the same error message.
And I tried several times always the same thing.
By the way I have a TSSTcorp SE-506BB and I look on the Internet and I think it's quite common, with this drive or another TSST
But at least for this disc, I come up with a solution :
1. Open MakeMKV.
2. Put the disc in the drive.
3. Click on Backup, put the directory and uncheck "Decrypt video files".
4. It would read.
5. Open the Backup with MakeMKV and hopefully it would work.
So try it if you want :)
