Problems with Storage via Time Capsule
Dr.Sven
#1 Post by Dr.Sven » Sun Oct 15, 2017 9:45 am
with the new version 1.10.7 I have massive problems when ripping a DVD and storing it to Time Capsule.
The version 1.10.6 did not show these problems at all... I hope you guys can check that and find
the bug.
Thanks and best,
Dr. Sven
Re: Problems with Storage via Time Capsule
#2 Post by Woodstock » Sun Oct 15, 2017 2:45 pm
"storing to Time Capsule", as in writing it directly to it as a network attached storage box, or Time Machine can't back up an MKV file to Time Capsule?
Either way, from the description of TC I find on the web, it would seem to be a TC issue, not a MakeMKV issue.
Dr.Sven
#3 Post by Dr.Sven » Sun Oct 22, 2017 11:36 am
Hey,
the problem is that there occurs endless negotiation between the HD and the 1.10.7 version. In the end it means to get a DVD ripped it takes 6 hours. Using the 1.10.6 version it just takes 15 minutes.
As it works flawless with the 1.10.6 there must be something in the new version which causes the problems.
However, I guess to reproduce the error you need to have a TC and just try it out :)
Cheers,
Sven
