question about registration key
timcat
Post by timcat »
I have the trial version on a machine that never gets connected to the internet and that is where I would like to have the complete shareware version. Will the registration key alone activate the full version or does it require an internet connection for this to happen? Can I simply transfer the downloaded registration key from a jump drive and activate the program that way?
I appreciate your time with my question. Tim
Re: question about registration key
The key alone does the activation.
Internet access is used to check for newer versions on start-up, and also to look for SVQ files if needed to deal with BD+ copy protection (see /svq/ for more information). Both can be disabled in the preferences.
timcat
Post by timcat »
Thanks for confirming that. I run XP on that machine and can't risk connecting it to the internet ever again. For my main computer I use linux Mint, but don't want to try installing MakeMKV for linux as it would be too much of a challenge. For some things I still need a Windows I guess...
Hmm... I wonder if MakeMKV for Windows would run under Wine? Someday, I might try that...
indyjoe1977
Post by indyjoe1977 »
timcat wrote:Thanks for confirming that. I run XP on that machine and can't risk connecting it to the internet ever again. For my main computer I use linux Mint, but don't want to try installing MakeMKV for linux as it would be too much of a challenge. For some things I still need a Windows I guess...
MakeMKV runs and installs like a dream under Linux Mint. I use it, and there is a simple install process for it. This is the link...though for whatever reason, it doesn't seem to be up at the moment. Hopefully, that changes. It worked a couple days ago.
