NO FUT FOR "WAR FOR THE PLANET OF THE APES" BLU RAY
vin1013
Post by vin1013 »
Hello, Mike:
No FUT for "War For the Planet of the Apes" blu ray.
Just sent you links of both the dump files and 6SVM files from the disc itself via Dropbox. Please check and thanks in advance for the coming update.
Best,
Vincent
horkonpon
Re: NO FUT FOR "WAR FOR THE PLANET OF THE APES" BLU RAY
Post by horkonpon »
I have the same problem with this BR in the spanish version.
I send a message with the links to download the dump file and the 5 SVM files of this BR (a little difference with the 6 SVM files of the previous message).
For more information, I update the program to the 1.10.8 version. The program loads 626 SVQ files but uses the generic SVQ file, so no FUT's.
Thanks in advance.
Best regards
Alberto
McStarfighter
Post by McStarfighter »
Did you have checked if the "forced" subtitles are a seperate subtitle lane without forced flags?
Some Blu Ray do have forced subs by this way!
horkonpon
Post by horkonpon »
McStarfighter wrote:Did you have checked if the "forced" subtitles are a seperate subtitle lane without forced flags?
Sorry, but I don't understand this.
McStarfighter
horkonpon wrote:Hi,
When a distributor creates the master for a Blu Ray, there are 2 options for the forced subs:
1) Marking the needed parts in the primary sub with "Forced" flags
2) Creating a seperate sub with the needed parts
If the distributor uses option 2, most time there are no "forced" flags and tools like MakeMKV or DVDFab can't find anything!
horkonpon
Post by horkonpon »
Well, I tried and finally the program used the correct SVQ file and everything went OK
Alberto
CineMan
Post by CineMan »
Hey everybody,
same problem here with the german version of the 3D BD
MK cannot finf the right fut.
When i use the pl 800 so its in 3d but with pixels in the movie.
In the BD Player plays fine.
Greetings
Cine
If you have not prevented MakeMKV from checking internet for updates (Preferences->General), it should pick up the new SVQ file when it is available. BD+ code is usually not language-release-specific.
CineMan
Post by CineMan »
yes it is activated. So what can i do ?
The normal BD Disk works, but not the 3D Version
Should i send dthe dumpfile ?
Cine
Is MakeMKV creating a BD+ dump file for the 3D version? If so, send the file to svq@makemkv.com so that Mike can look at it.
