The Last WItch Hunter
bmillham
#1 Post by bmillham » Wed Oct 11, 2017 10:50 pm
Hi all,
I'm trying to rip my copy of The Last Witch Hunter, and it shows around 300 versions of the main title (all around the same size, and time varies by around a minute or 2)
How do I find the right title to save?
bmillham
Re: The Last WItch Hunter
#2 Post by bmillham » Wed Oct 11, 2017 11:17 pm
Ok, my bad! I did what I should have, and searched the forum and found the great FindM2TS.pl script by DJRumpy. I know know that it's title 216 for the copy I have.
Many thanks to DJRumpy for the script!
#3 Post by Woodstock » Wed Oct 11, 2017 11:25 pm
Do you have Java Runtime Environment (JRE, available from java.com) installed? MakeMKV should make an effort to uncover the "Main Feature" if you do.
If it doesn't, see this topic: http://makemkv.com/forum2/viewtopic.php ... 30&p=48158
bmillham
#4 Post by bmillham » Wed Oct 11, 2017 11:46 pm
Yes, Java is installed. This is a linux system BTW.
#5 Post by Woodstock » Thu Oct 12, 2017 3:31 am
When MakeMKV invokes Java on disks like this, it should appear in the log window, as well as in the debug log if you have that turned on. On my Windows system, it looks like this (just so happens I ripped 3 Summit/Lionsgate disks this week):
Found java version=1.8.0.121 path=C:\Program Files (x86)\Java\jre1.8.0_121\bin\java.exe
003344:0000 Using Java runtime from C:\Program Files (x86)\Java\jre1.8.0_121\bin\java.exe
Does the log show any attempt to load the JRE?
mtbdrew
#6 Post by mtbdrew » Mon Oct 15, 2018 3:55 pm
I am not seeing the Java message you mentioned in the message window or the log file.
MakeMKV_log.txt
(19.14 KiB) Downloaded 740 times
