Command line to convert has problem with output file name
xilex
#1 Post by xilex » Wed Oct 11, 2017 4:07 am
Hi all, I am utilizing the command line to automate ripping from a DVD. I tried the following command but it results in an error:
C:\>"d:\Program Files (x86)\MakeMKV\makemkvcon64.exe" mkv disc:0 --minlength=600 all c:\test
Title #2 was added (20 cell(s), 2:14:37)
Saving 1 titles into directory c:\test
Error 'OS error - The system cannot find the path specified' occurred while creating 'c:\test/title00.mkv'
Failed to save title 0 to file c:\test/title00.mkv
0 titles saved, 1 failed
Copy complete. 0 titles saved, 1 failed.
I followed one of the examples in usage.txt but I'm not sure why it's using a forward-slash in the output file. Thanks.
Re: Command line to convert has problem with output file nam
#2 Post by Woodstock » Wed Oct 11, 2017 12:40 pm
In this usage, Windows does not care if you use \ or / for the directory separator; that is a limitation built into CMD.EXE and COMMAND.COM, not Windows itself.
The question is, does the user that is running makemkvcon64.exe have permission to write to C:\test?
At the command prompt, do you get an error if you enter this command?
ECHO "This is a test" > C:\TEST\TEST.TXT
