Hell or High Water missing MPLS file
nvader2000
#1 Post by nvader2000 » Mon Oct 02, 2017 8:37 pm
I was watching Hell or High Water on Blu-Ray and noticed that chapters jumping around in the wrong order. This tells me that I did not transcode the correct title. I used BDInfo and it tells me that it should be 0865.mpls. I can see the file on the dis but MakeMKV does not.
Please advise.
Re: Hell or High Water missing MPLS file
#2 Post by Woodstock » Mon Oct 02, 2017 9:08 pm
If you have Java Runtime Environment installed, 0865.mpls is probably one of the first titles listed.
nvader2000
#3 Post by nvader2000 » Mon Oct 02, 2017 9:35 pm
I do have JR installed, but why does MakeMKV not see this playlist?
#4 Post by Woodstock » Tue Oct 03, 2017 2:53 am
I cannot say whether or not it sees it without watching what is in the logs. What I'm saying is that, if this title does use playlist obfuscation, it is highly likely that MakeMKV has moved the playlist detected to the top of the list, and not buried it in order.
Which file is listed as "main playlist"?
According to the original thread on this subject from last November, differently sourced disks disks had different available playlists.
https://www.makemkv.com/forum2/viewtopi ... =8&t=15338
Also, if MakeMKV is NOT showing the correct playlist for a given disk when the JRE is installed and active, Mike asked for assistance in fixing that:
https://www.makemkv.com/forum2/viewtopi ... =8&t=14330
netwrxman
#5 Post by netwrxman » Thu Oct 12, 2017 2:49 pm
Resurrecting this older thread- so I have the latest JRE v1.8.0_144 installed and MKV is still not listing the FPL. Does anyone have any ideas why?
Just wondering if I can provide some information to support the community...
Lovely Rita
#6 Post by Lovely Rita » Thu Oct 12, 2017 6:27 pm
netwrxman wrote:Just wondering if I can provide some information to support the community...
Follow these instructions.
The JRE helper is a work in progress.
I've sent Mike a handful of needed files when I encounter a disc that "should" designate the main feature.
Registered User :wink:
Buy MakeMKV
