Around The World with Willy Fog Vol. 2 - titles appear as on
matt198t
Post by matt198t »
I believe there are 5 titles on the disc.
The big file even fails to rip.
MakeMKV v1.10.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\mattw/MakeMKV_log.txt
Title #1 has length of 30 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #2 has length of 13 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #3 was added (5 cell(s), 2:05:12)
DEBUG: Code 233 at gfXEQ/OCrn8XxM9irUtmo3J3:0
Saving 1 titles into directory //matt-server/3tb-1a/3TB-1A TV Shows/Around the World with Willy Fog/Season 1 (1983)
DEBUG: Code 3221225489 at h5xfKK 7!E4+?t`3k:29393654
AV synchronization issues were found in file '//matt-server/3tb-1a/3TB-1A TV Shows/Around the World with Willy Fog/Season 1 (1983)/title00.mkv' (title #1)
AV sync issue in stream 0 at 0:50:05.240 : video frame timecode differs by +120ms
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '1703168000'
DEBUG: Code 100864261 at __3PiwfHcXV.eS,('h:121262969
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '1704964096'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '1704966144'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '1706162176'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '1706164224'
DEBUG: Code 0 at xj`@hhi{FlXg[84As`IS:29395034
DEBUG: Code 0 at |9">|TUQ}<hl~H[bL]&:213129915
DEBUG: Code 0 at xj`@hhi{FlXg[84As`IS:121262647
DEBUG: Code 833088 at xj`@hhi{FlXg[84As`IS:213129593
DEBUG: Code 0 at e)PjWJg$X&%'=4Yq=x4Qw:29399197
Failed to save title 0 to file //matt-server/3tb-1a/3TB-1A TV Shows/Around the World with Willy Fog/Season 1 (1983)/title00.mkv
Encountered 64 errors of type 'Read Error' - see /errors/dvdread/
0 titles saved, 1 failed
Re: Around The World with Willy Fog Vol. 2 - titles appear a
The biggest problem is that something is preventing your drive from reading parts of the disk:
Cleaning the disk is the first step.
You're only seeing one title because you excluded anything shorter than 4 minutes from being available, and it appears that the large file contains 5 episodes, each in its own chapter.
