BETA key not working
ggking7
My evaluation period expired so I tried to use the BETA key as described here:
http://www.makemkv.com/forum2/viewtopic ... 1218#p4421
but makemkv says the key is expired and removes it. Can we still use makemkv without purchasing since it's in BETA?
Re: BETA key not working
Yes, the key is updated.
ggking7
I don't get the message about the key being removed from ~/.MakeMKV/settings.conf any more, but it still tells me my evaluation period is over and it doesn't let me rip a disc. I'm on 1.5.5. This is all I have in settings.conf:
appKey = "T-o4vIHFtFMG0O4H5u0NT40YJcRLnfXk2j1O0Yiy3O6YrwbHga7kWEYays4AS6MTK9h9"
I've double-checked permissions on the folder and file.
ggking7
I forgot the underscore in app_Key.
Archo
Makemkv beta expired and there isnt a new one. Batch encode errors out cause of trial expiration but i believe you are still allowed to use Makemkv regardless of beta expiration (at least until our of beta).
Romansh
Yes, there is: http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053Archo wrote:Makemkv beta expired and there isnt a new one.
hjr333
Hi there,
the beta key is not working again. Although it should until the end of September
regards
regards
The link currently has a key that expired a couple of days ago. The message you're replying to is 6 years old!
When Mike replaces it, the note at the bottom will say something like....
Right now, it's 1 October in many parts of the world, so the September key doesn't work anymore.and is valid until end of (probably) November 2017.
dorgan
Would be really great if this didn't happen a couple times a month... Not sure I want to consider supporting something that stops working until its updated by the owner...
It hasn't happened to me since 2011. Of course, that was when I bought a permanent key.
The keys are typically good for two months. If you're having it happen 'a couple of times a month', there is something else going on.
