American Grafitti
jbelkin800
American Grafitti
#1 Post by jbelkin800 » Sat Sep 30, 2017 4:26 am
Does not rip
Lovely Rita
Re: American Grafitti
#2 Post by Lovely Rita » Sat Sep 30, 2017 1:45 pm
And the error message(s) MakeMKV reported are???
Registered User :wink:
Buy MakeMKV
yorgo
#3 Post by yorgo » Sun Oct 01, 2017 2:10 am
jbelkin800 wrote:Does not rip
I can assure you that it does, at least I was able to back up my copy many years ago. As Lovely Rita correctly asked, what error message are you seeing? Please post.
1972SM
#4 Post by 1972SM » Thu Oct 19, 2017 10:32 pm
I am about try try to rip American Grafitti. Not expecting a successful outcome, sad to say....
yorgo
#5 Post by yorgo » Fri Oct 20, 2017 2:54 am
If it does not rip, then the fault is not with MakeMKV as I've successfully backed up this title. Per Blu-Ray.com, there is no new remastering of this title; repackaging yes but nothing more. Please post an error report if your copy does not rip.
1972SM
#6 Post by 1972SM » Sat Oct 21, 2017 11:43 pm
I keep trying, but no luck. Eleven files were created, all trailers and interview segments.
The main movie... just won;t copy. I would be happy to purchase whatever external drive the collective wisdom of the forum would recommend. My Pioneer clearly isn't up to the task. Here is the error report log:
MakeMKV v1.10.7 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:SYSTEM RESOURCE FAILURE' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom2'
File 00308.mpls was added as title #0
File 00020.mpls was added as title #1
File 00344.mpls was added as title #2
File 00300.mpls was added as title #3
Title 00309.mpls is equal to title 00308.mpls and was skipped
File 00800.mpls was added as title #4
Title 00310.mpls is equal to title 00308.mpls and was skipped
Title 00311.mpls is equal to title 00308.mpls and was skipped
Title 00312.mpls is equal to title 00308.mpls and was skipped
Title #00014.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50136.m2ts has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50142.m2ts has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50143.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50199.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50200.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 50201.m2ts was added as title #5
File 50202.m2ts was added as title #6
File 50203.m2ts was added as title #7
File 50204.m2ts was added as title #8
File 50205.m2ts was added as title #9
File 50206.m2ts was added as title #10
File 50207.m2ts was added as title #11
File 50208.m2ts was added as title #12
File 50209.m2ts was added as title #13
Title #50214.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50140.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00344.mpls is equal to title 00800.mpls and was skipped
Saving 13 titles into directory D:/Video
Forced subtitles track #3 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
Forced subtitles track #7 turned out to be empty and was removed from output file
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '9718198272'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '9718198272'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '9718198272'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '9718659072'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '9718659072'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '9719377920'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '9719377920'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '9721018368'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '9721018368'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '9723310080'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '9723310080'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '9723574272'
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '9731045376'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '9731045376'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '9731045376'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '9731764224'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '9731764224'
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '9732225024'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '9732225024'
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '9744875520'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '9744875520'
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '9744875520'
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '18918801408'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '18918801408'
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '18918801408'
Failed to save title 3 to file D:/Video/American_Graffiti_t03.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '4393857024'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '4393857024'
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '18918537216'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '18918537216'
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '18925682688'
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '18925940736'
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/50201.m2ts' at offset '18927452160'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '18927452160'
Failed to save title 4 to file D:/Video/American_Graffiti_t04.mkv
Encountered 50 errors of type 'Read Error' - see /errors/read/
11 titles saved, 2 failed
#7 Post by Woodstock » Sun Oct 22, 2017 2:27 am
Do you have any device that is particularly SLOW that you can write to? Such as a USB2 flash drive? It would have to be big enough to hold the main feature, and be formatted in either ExFAT or NTFS.
Hardware read errors like you're seeing occur most often with drives exceeding their available power, but they CAN be caused by failing drives. And the program has no way to throttle its read requests to the optical drive, so it will try to read as fast as it can write. Slowing the write with a slow media MAY help.
1972SM
#8 Post by 1972SM » Sun Oct 22, 2017 3:34 am
Woodstock wrote:Do you have any device that is particularly SLOW that you can write to? Such as a USB2 flash drive? It would have to be big enough to hold the main feature, and be formatted in either ExFAT or NTFS.
Sure! i can try a USB drive tomorrow; thanks, I'll let you know what happens.
1972SM
#9 Post by 1972SM » Mon Oct 23, 2017 3:44 pm
Interesting side note: The American Graffiti DVD plays fine on my Pioneer BR DVD player burner (USB) using the software that came with my HP PC, "Power Media Player." However, it will NOT play using VLC media player, which I thought was state-of-the-art!
