Titanic
tim909
Titanic
Post by tim909 »
I have tried two copies of the main movie disc of Titanic bluray, neither worked. They both fail with errors:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '930637824'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '930637824'
Both discs looked to be in perfect condition. The included bonus disc which has just special features ripped fine. The drive has not had problems with other discs that did not have some kind of scratch/physical damage.
Re: Titanic
Do the errors occur at the same position on the title for both disks? Do they occur at the same position each time you attempt the rip of either disk?
Exact same location would generally be an error, sometimes deliberate, in the manufacturing process. Moving around between rips tends to be drive related.
The most common drive related "failure", which matches your error succession, is an over-speed condition on a USB-powered drive. As the drive spins up, it draws more power than the USB port can provide... and shuts down. Shutting down brings the power back, so it can restart after a while, but not until the operating system says, "there is no drive available".
The solution to that is to make sure the drive has adequate power, by plugging it into a fully-powered USB port (two, if it has a two-headed cable), rather than a hub.
tim909
Re: Titanic
Post by tim909 »
Woodstock wrote:Do the errors occur at the same position on the title for both disks? Do they occur at the same position each time you attempt the rip of either disk?
I believe they each failed at different points, but I did attempt one of them multiple times and it did seem like it was failing after a similar amount of time.
It is not being used over usb.
Re: Titanic
Not being on USB and having the disconnect message is strange - I've only seen similar reports a few times, and most of those were laptop drives.
tim909
Re: Titanic
Post by tim909 »
Woodstock wrote:Not being on USB and having the disconnect message is strange - I've only seen similar reports a few times, and most of those were laptop drives.
well....it's in a desktop
I don't remember ever using it with an adapter and it's worked mostly fine up to now
someone else in the read here first thread said they had the same errors with a brand new disc, and in two different drives....that leads me to think it might have something to do with the software
Re: Titanic
Yes, it is possibly a software error.
Just remember which software is reporting the read and hardware disconnect errors to MakeMKV...
