MakeMKV 1.10.7 Won't Run on Mac OSX 10.11.6 El Capitan
drbubba
Post by drbubba »
Until today MakeMKV 1.10.7 was running under Mac OSX 10.11.6 El Capitan just fine. When I tried to open it today it said my version was out of date and that I needed to download the most current version to continue. 1.10.7 IS the most current version, so OK, I deleted the app and re-installed. Got the message that I needed to either update to a more current version or enter a registration key. OK, so I entered the current beta key (T-CDPEBnWdamx7Qt2sdl60vp0xsRQsH3HBJ6RifOAvJedhinALlaoCJu30fAMQ4iWsx0) which is good until the end of Sept (today is 29 Sept so it should still work). Now I'm in a recycling loop of "need to install the latest version" - "you key has expired" - crash. Is anyone else having this problem or is it just me? Any recommendations? Thanks.
drbubba
Re: MakeMKV 1.10.7 Won't Run on Mac OSX 10.11.6 El Capitan
Post by drbubba »
I tried connecting a difference drive and everything worked ... so it looks like I've got a funky drive ... but problem resolved.
joensson
Post by joensson »
I have a problem very similar to this.
I don't have another drive to test with.
I have uninstalled the old version.
Downloaded and installed the latest version 1.10.7 - opened Register and entered the beta key from https://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
It says Thank you and that I should restart the application for the change to take effect.
When I do it behaves as though it has been registered and I can start a scan of a BR disk.
A few seonds after scanning has started I get a dialog that says that the key has expired (I am very certain that I have the latest beta key - but maybe it has expired a day too early - today is September 30th, so it ought to still be valid, right?
If I click ok to the error I get a new dialog that says the application itself is too old - I have downloaded and installed 1.10.7 - there is no newer version available.
Kind of stuck for now - hoping the problem will go away when a new beta key is available.
You can set your system date back to 9/20, start MakeMKV, then reset the date to the current day. MakeMKV only checks for key expiration at start-up, so this is a work-around until the key in the linked message is replaced.
Hopefully, Mike will take care of that quickly.
drbubba
Post by drbubba »
Thank you Woodstock. Appreciate your reply and your assistance. Today is 01 Oct, so I'm hoping a new key will be available soon.
DavidHOO
Post by DavidHOO »
I had the same problem yesterday, then I reinstalled the newest version of MakeMKV, useful!
