Reducing DTS-HD track to core AFTER ripping
cpaqf1
Post by cpaqf1 »
Quick question, for movies that require a lot of a audio sync work by MakeMKV (example seamless branching BDs), is it safe to reduce the DTS-HD track to core after ripping it with MakeMKV or will that new track lose the syncing work done by MakeMKV? I would test it, but I'd have too many files to test, and I wanna batch process them with mkvmerge.
thanks
Re: Reducing DTS-HD track to core AFTER ripping
The core should not lose sync just because you removed the loss-less part. The adjustments made to the audio sync make the audio and video tracks the same length.
Normally, though, MakeMKV can give you two tracks on an DTS-HD, the "core" and the loss-less versions, because of limitations in the MKV format. I configure my copy to include both tracks (actually, ALL audio tracks) so that I can have options later.
cpaqf1
Post by cpaqf1 »
Woodstock wrote:The core should not lose sync just because you removed the loss-less part. The adjustments made to the audio sync make the audio and video tracks the same length.
okay thank you,
do you happen to know which track MakeMKV cuts to make them the same length ? audio / video
MakeMKV reports sync adjustments in the log, and what it did about them, like this:
004008:0010 AV sync issue in stream 2 at 0:01:25.085 with duration of 7ms : encountered overlapping frame, audio skew is +35ms
004008:0010 AV sync issue in stream 2 at 0:01:25.120 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +3ms
004008:0010 AV sync issue in stream 1 at 0:01:25.085 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0ms
Usually it involves dropping just one or two "frames" from the audio tracks.
