the only issue i have is with the naming of the second track before conversion:
how can i get it to automaticly say the conversion?
like this one does:
here is the profile:
<?xml version="1.0" encoding="utf-8"?>
<profile>
<!-- profile name - TrueHD add DD5.1 -->
<name lang="eng">TrueHD-DD</name>
<!-- Common MKV flags -->
<mkvSettings
ignoreForcedSubtitlesFlag="true"
useISO639Type2T="false"
setFirstAudioTrackAsDefault="true"
setFirstSubtitleTrackAsDefault="true"
setFirstForcedSubtitleTrackAsDefault="true"
insertFirstChapter00IfMissing="true"
<!-- Settings overridable in preferences -->
<profileSettings
app_DefaultSelectionString="-sel:all,+sel:(lossless|eng),-sel:(core),-sel:(lossy),-sel:mvcvideo,=100:all,-10:favlang"
<!-- Output formats currently supported by MakeMKV -->
<outputSettings name="copy" outputFormat="directCopy">
<description lang="eng">Copy track as is</description>
<description lang="ger">Track 1:1 kopieren</description>
</outputSettings>
<!-- AC3 Encoding -->
<outputSettings name="AC3-640" outputFormat="AC3">
<description lang="eng">Save as AC3 (640kbps)</description>
<extraArgs>-b 640k</extraArgs>
</outputSettings>
<!-- Dolby Digital 5.1 Surround-->
<audioMixSettings name="DD5.1"
outputChannelLayout="5.1"
mix="DolbyDigital">
<description lang="eng">Dolby Digital 5.1 Surround</description>
</audioMixSettings>
<!-- Default rule - copy as is -->
<trackSettings input="default">
<output outputSettingsName="copy"
defaultSelection="$app_DefaultSelectionString">
</output>
</trackSettings>
<!-- Add AC3 640kbps 5.1 Track to Multi Channel TrueHD and keep TrueHD Track-->
<trackSettings input="TRUEHD-multi">
defaultSelection="$app_DefaultSelectionString,+sel:all">
</output>
<output outputSettingsName="AC3-640"
audioMix="DD5.1">
</output>
</trackSettings>
</profile>
