Wonder Woman not ripping
pointguard86
#1 Post by pointguard86 » Thu Sep 21, 2017 7:10 am
Not sure if this is the way to post it, but I'm unable to rip Wonder Woman.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00296.m2ts' at offset '14224982016'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '14224982016'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00296.m2ts' at offset '14225111040'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '14225111040'
Failed to save title 1 to file
Encountered 12 errors of type 'Read Error' - see /errors/read/
stuckinkodiagain
Re: Wonder Woman not ripping
#2 Post by stuckinkodiagain » Thu Sep 21, 2017 7:15 am
This looks like a drive and/or dirty disc error. I’d try cleaning the disc, or using a different drive (sometimes just restarting helps). I can confirm Wonder Woman copies just fine with the latest version of MakeMKV.
pointguard86
#3 Post by pointguard86 » Thu Sep 21, 2017 7:36 am
Thanks for letting me know, I'll try that.
mendocenter55
#4 Post by mendocenter55 » Sun Nov 12, 2017 7:15 am
Im experiencing the same thing. The disc is clean and I just reinstalled MKV on a restored HDD so there shouldn't be any issues. Ill try a reboot i guess. :?
#5 Post by Woodstock » Sun Nov 12, 2017 3:26 pm
If you're experiencing the SAME errors, including the "Input/output error", I'd suspect you're using a USB drive that gets all of its power from the USB port. Such drives need a "fully powered port" to work at the speeds MakeMKV can read from them, and most USB hubs do not qualify.
cherishjoo
#6 Post by cherishjoo » Sun Feb 18, 2018 12:05 pm
Is this issue solved?
Best Bluray DVD Ripping Solution
