I wish this worked more often - I was excited when I finally got it working on my iMac, but with quite a few movies it fails to flag anything at all (such as The Big Sick). This feature seems to work better on Windows than Mac.Woodstock wrote:But, if you have the Java Runtime Environment installed (from java.com), MakeMKV will make an educated guess at the right title, and move it to the top of the list
The Big Sick
KENSAI
Re: The Big Sick
asr101
Re: The Big Sick
What is the procedure to submit information to MakeMKV when the JAVA does not work?Woodstock wrote:But, if you have the Java Runtime Environment installed (from java.com), MakeMKV will make an educated guess at the right title, and move it to the top of the list.
I only see this work occasionally, because I avoid buying titles from Lionsgate.
Re: The Big Sick
http://www.makemkv.com/forum2/viewtopic.php?f=8&t=14330What is the procedure to submit information to MakeMKV when the JAVA does not work?
WAYFLIX
Re: The Big Sick
Just watched it. Confirmed!mitchell_pgh wrote:Same here... fingers crossed.WAYFLIX wrote:Thanks. Awaiting confirmation!
asr101
Re: The Big Sick
I have submitted the back up file. Hope it helps.
wylde31
Re: The Big Sick
Where do you find this information in PowerDVD? Apologies in advance for the noob question.salamonka wrote:I just got PowerDVD. 00920 is what you want.
Title information
Name: The Big Sick (2017) (English)
Source file name: 00920.mpls
Duration: 2:00:24
Chapters count: 16
Segment count: 11
Segment map: 505,506,502,503,510,501,500,508,509,504,507
File name: The_Big_Sick_(2017)_t344.mkv
wylde31
Re: The Big Sick
Nevermind, I found the right forum post.
jandjfrench
Re: The Big Sick
My disc does not have a "00920.mpls". I arbitrarily selected "00058.mpls" and surprisingly the resulting mkv shows everything in the proper order.
MZAdotcom
RE: The Big Sick
Title information
Duration: 2:00:24
Chapters count: 16
Segment count: 11
Just watched this flick and can confirm that this info is correct for the Netflix rental version. The only detail that was different was in the file name: The_Big_Sick_(2017)_t345.mkv, NOT The_Big_Sick_(2017)_t344.mkv.
Cheers.
@HTPC: Intel NUC HTPC [BOXDN2820FYKH0] | Plextor 128GB SIII SSD | G.SKILL 8GB DDR3 1333 RAM | Win 10 Pro | SAMSUNG 55" LED HDTV | Harman/Kardon 5.1 AV Receiver [AVR 1565] | Dolby TrueHD | DTS-MA HD | Polk Audio 5.1 Home Theater System w/10" SW
rogodeter
Re: The Big Sick
hvnphoto wrote:For the Retail Version, it is 00544.MPLS.marianiode wrote:Anyone know what the right file name for this tittle is? Thanks...
Do you have the track/chapter details so I can compare that to my distribution. i don't have a 920 so this might be the right one.
yorgo
Re: The Big Sick
Check/compare to the segment map posted by salamonka: http://www.makemkv.com/forum2/viewtopic ... 594#p57486
Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
rogodeter
Re: The Big Sick
Thanks, but I looked through all the title (albeit manually scanning them visually) but I couldn't find a single title in the hundreds presented by MakeMKV, that has 506 in the second index of the list. I guess with different distributions (retail, netflix, redbox) they even change the numbers/names associated with each title. Is that right?yorgo wrote:Check/compare to the segment map posted by salamonka: http://www.makemkv.com/forum2/viewtopic ... 594#p57486
rogodeter
Re: The Big Sick
I just re-verified it -- there's not a single file with 506 in position 2 on the segment map. I found one title with 506 in it and it was the only segment.yorgo wrote:Check/compare to the segment map posted by salamonka: http://www.makemkv.com/forum2/viewtopic ... 594#p57486
Title information
Name: The Big Sick (English)
Source file name: 00043.mpls(3)
Duration: 0:26:15
Chapters count: 4
Segment count: 1
Segment map: 506
File name: The_Big_Sick_t16.mkv-
pimpinonline
Re: The Big Sick
Thank you!salamonka wrote:I just got PowerDVD. 00920 is what you want.
Title information
Duration: 2:00:24
Chapters count: 16
Segment count: 11
Drilian
Re: The Big Sick
I can verify that this worked for my disk, too (thanks, because I definitely picked some wrong ones before I noticed this one).jandjfrench wrote:My disc does not have a "00920.mpls". I arbitrarily selected "00058.mpls" and surprisingly the resulting mkv shows everything in the proper order.
For reference it's:
Name: The Big Sick
Source file name: 00058.mpls
Duration: 2:00:24
Chapters count: 16
Segment count: 11
Segment map: 502,505,510,509,503,500,504,501,507,508,506
