I'm getting this error when running make in the makemkv-oss-1.10.6.
[root@paulfamilylinux makemkv-oss-1.10.6]# make
mkdir -p out
gcc -g -O2 -D_linux_ -D_GNU_SOURCE -D_REENTRANT -shared -Wl,-z,defs -oout/libmakemkv.so.1.full -I./libebml/inc -DEBML_NO_READ -DEBML_STRICT_API -DEBML_DEBUG \
-I./libmatroska/inc -I./libmakemkv/inc -I./sstring/inc -I./makemkvgui/inc -I./libabi/inc \
-I./libffabi/inc -DDCA_LOG -DDCA_FFMALLOC libebml/src/EbmlBinary.cpp libebml/src/EbmlContexts.cpp libebml/src/EbmlCrc32.cpp libebml/src/EbmlDate.cpp libebml/src/EbmlDummy.cpp libebml/src/EbmlElement.cpp libebml/src/EbmlFloat.cpp libebml/src/EbmlHead.cpp libebml/src/EbmlMaster.cpp libebml/src/EbmlSInteger.cpp libebml/src/EbmlString.cpp libebml/src/EbmlSubHead.cpp libebml/src/EbmlUInteger.cpp libebml/src/EbmlUnicodeString.cpp libebml/src/EbmlVersion.cpp libebml/src/EbmlVoid.cpp libebml/src/IOCallback.cpp libebml/src/MemIOCallback.cpp libmatroska/src/FileKax.cpp libmatroska/src/KaxAttached.cpp libmatroska/src/KaxAttachments.cpp libmatroska/src/KaxBlock.cpp libmatroska/src/KaxBlockData.cpp libmatroska/src/KaxCluster.cpp libmatroska/src/KaxContexts.cpp libmatroska/src/KaxCues.cpp libmatroska/src/KaxCuesData.cpp libmatroska/src/KaxInfoData.cpp libmatroska/src/KaxSeekHead.cpp libmatroska/src/KaxSegment.cpp libmatroska/src/KaxTracks.cpp libmatroska/src/KaxVersion.cpp libmatroska/src/KaxSemantic.cpp libmakemkv/src/ebmlwrite.cpp libmakemkv/src/libmkv.cpp libmakemkv/src/version.cpp libmakemkv/src/world.cpp libmakemkv/src/stdstring.cpp sstring/src/sstring.cpp \
libabi/src/ossl_aes.c libabi/src/ossl_sha.c libabi/src/ossl_ec.c libabi/src/zlib.c libabi/src/xpat.c libabi/src/libm.c libabi/src/httplinux.cpp makemkvgui/src/api_linux.cpp libabi/src/sys_linux.c makemkvgui/src/spawn_posix.cpp libffabi/src/ffabi.c libffabi/src/mlp.c libffabi/src/log.c libffabi/src/audio_convert.c libffabi/src/audio_mix.c libffabi/src/audio_mix_matrix.c libffabi/src/dcadec/bitstream.cpp libffabi/src/dcadec/core_decoder.cpp libffabi/src/dcadec/dca_context.cpp libffabi/src/dcadec/dmix_tables.cpp libffabi/src/dcadec/exss_parser.cpp libffabi/src/dcadec/idct_fixed.cpp libffabi/src/dcadec/interpolator.cpp libffabi/src/dcadec/interpolator_fixed.cpp libffabi/src/dcadec/interpolator_float.cpp libffabi/src/dcadec/ta.cpp libffabi/src/dcadec/xll_decoder.cpp libffabi/src/dcadec/idct_float.cpp \
-DHAVE_BUILDINFO_H -Itmp -I/usr/include/ffmpeg \
-fPIC -Xlinker -dy -Xlinker --version-script=libmakemkv/src/libmakemkv.vers \
-Xlinker -soname=libmakemkv.so.1 -lc -lstdc++ -lcrypto -lz -lexpat -lavcodec -lavutil -lrt -lm -lrt
libmakemkv/src/libmkv.cpp: In member function ‘void MyMkvTrackInfo::RenderStat(libmatroska::KaxTags&, unsigned int, uint64_t, const char*)’:
libmakemkv/src/libmkv.cpp:384:53: error: expected ‘)’ before ‘PRIu64’
sprintf_s(buffer,sizeof(buffer),"%" PRIu64,values);
libmakemkv/src/libmkv.cpp:392:49: error: expected ‘)’ before ‘PRIu64’
sprintf_s(buffer,sizeof(buffer),"%" PRIu64,stat_bytes);
In file included from libffabi/src/dcadec/core_decoder.cpp:23:0:
libffabi/src/dcadec/fixed_math.h: In function ‘int64_t round__(int64_t, int)’:
libffabi/src/dcadec/fixed_math.h:25:31: error: ‘INT64_C’ was not declared in this scope
return (a + (INT64_C(1) << (bits - 1))) & ~((INT64_C(1) << bits) - 1);
libffabi/src/dcadec/fixed_math.h: In function ‘int32_t norm__(int64_t, int)’:
libffabi/src/dcadec/fixed_math.h:33:41: error: ‘INT64_C’ was not declared in this scope
return (int32_t)((a + (INT64_C(1) << (bits - 1))) >> bits);
In file included from libffabi/src/dcadec/core_decoder.cpp:19:0:
libffabi/src/dcadec/core_decoder.cpp: In function ‘void dequantize(int*, const int*, int, int, bool)’:
libffabi/src/dcadec/core_decoder.cpp:556:54: error: ‘INT64_C’ was not declared in this scope
int nbits = 64 - dca_clz64(step_scale | INT64_C(1));
libffabi/src/dcadec/common.h:35:41: note: in definition of macro ‘dca_clz64’
#define dca_clz64(x) __builtin_clzll(x)
libffabi/src/dcadec/core_decoder.cpp: In function ‘int parse_subframe_audio(core_decoder*, int, HeaderType, int, int*, int*)’:
libffabi/src/dcadec/core_decoder.cpp:746:44: error: ‘INT64_C’ was not declared in this scope
int64_t err = INT64_C(0);
libffabi/src/dcadec/core_decoder.cpp: In function ‘int core_filter(core_decoder*, int)’:
libffabi/src/dcadec/core_decoder.cpp:995:47: error: ‘INT64_C’ was not declared in this scope
int64_t res1 = INT64_C(2097471) * samples[n] + INT64_C(6291137) * history;
libffabi/src/dcadec/core_decoder.cpp: In function ‘int parse_x96_subframe_audio(x96_decoder*, int, int, int*)’:
libffabi/src/dcadec/core_decoder.cpp:1477:44: error: ‘INT64_C’ was not declared in this scope
In file included from libffabi/src/dcadec/dca_context.cpp:23:0:
return (a + (INT64_C(1) << (bits - 1)))[root@paulfamilylinux makemkv-oss-1.10.6]# make
mkdir -p out
In file included from libffabi/src/dcadec/idct_fixed.cpp:20:0:
libffabi/src/dcadec/idct_fixed.cpp: In function ‘void dct_a(const int*, int*)’:
libffabi/src/dcadec/idct_fixed.cpp:65:32: error: ‘INT64_C’ was not declared in this scope
int64_t res = INT64_C(0);
In file included from libffabi/src/dcadec/interpolator_fixed.cpp:22:0:
libffabi/src/dcadec/interpolator_fixed.cpp: In function ‘void interpolate_lfe_fixed_fir(int*, int*, int, bool, bool)’:
libffabi/src/dcadec/interpolator_fixed.cpp:37:36: error: ‘INT64_C’ was not declared in this scope
libffabi/src/dcadec/interpolator_fixed.cpp: In function ‘void interpolate_sub32_fixed(interpolator*, int*, int**, int**, int, bool)’:
libffabi/src/dcadec/interpolator_fixed.cpp:88:36: error: ‘INT64_C’ was not declared in this scope
libffabi/src/dcadec/interpolator_fixed.cpp:103:36: error: ‘INT64_C’ was not declared in this scope
libffabi/src/dcadec/interpolator_fixed.cpp: In function ‘void interpolate_sub64_fixed(interpolator*, int*, int**, int**, int, bool)’:
libffabi/src/dcadec/interpolator_fixed.cpp:162:36: error: ‘INT64_C’ was not declared in this scope
libffabi/src/dcadec/interpolator_fixed.cpp:177:36: error: ‘INT64_C’ was not declared in this scope
In file included from libffabi/src/dcadec/interpolator_float.cpp:22:0:
In file included from libffabi/src/dcadec/xll_decoder.cpp:21:0:
libffabi/src/dcadec/xll_decoder.cpp: In function ‘void xll_filter_band_data(xll_chset*, int)’:
libffabi/src/dcadec/xll_decoder.cpp:618:40: error: ‘INT64_C’ was not declared in this scope
make: *** [out/libmakemkv.so.1.full] Error 1
mkdir -p out
libffabi/src/dcadec/fixed_math.h:25:31: error: ‘INT64_C’ was not declared in this scope[root@paulfamilylinux makemkv-oss-1.10.6]# make
mkdir -p out
Centos 7 version 1.10.6 error
zeroepoch
Re: Centos 7 version 1.10.6 error
I happen to have a new version of GCC available on my RHEL 6.5 system which may have helped. I used the following configure line to fix the problem.
Try giving the above CFLAGS variable and see if that helps. You might also need to add "-D__STDC_CONSTANT_MACROS" in your case.
./configure CC=/tools/local/gcc-6.2.0/bin/gcc CXX=/tools/local/gcc-6.2.0/bin/g++ CFLAGS="-g -O2 -D__STDC_FORMAT_MACROS"
