SG Universe S1 1 Episode out of 3 is corrupt
suprkain
Post by suprkain » Sun Sep 17, 2017 11:33 pm
I know typically when posting something I should submit a log file, however I cannot because the log file isn't finished because the program locks up. I am trying to rip Stargate Universe S1 and I am only having trouble with 1 episode off of 1 disc. In the scroll down box I am seeing this:
The Source file '/BDMV/STREAM/00801.m2ts' is corrupt or invalid at offset 4374343680, attempting to work around DEBUG: Code 0 at e?((nCT78];ss@@az/3A(:213131341
I am able to watch the episode on multiple blu rays and even ripped it with a trial version of bytecopy. Is there something else I can do to get this single episode?
Re: 1 Episode out of 3 is corrupt
Post by Woodstock » Sun Sep 17, 2017 11:53 pm
Likely a dirty disk; once it finishes, clean it with a damp, soft cloth and try again.
suprkain
Post by suprkain » Tue Sep 19, 2017 11:22 am
I tried cleaning it several times, but it doesn't work. It still locks up the program.
Post by Woodstock » Tue Sep 19, 2017 12:44 pm
If it "locks up" the program, there should be entries in the system log about the lock-up.
suprkain
Post by suprkain » Tue Sep 19, 2017 1:03 pm
When I try to open the log it won't open because I had to end the task. So I don't get anything from there but I'll try it again once I get home
Post by Woodstock » Tue Sep 19, 2017 2:00 pm
The system logs (like Windows Event Viewer - you haven't mentioned what operating system you're using) persist until you delete them, regardless of what programs are running.
MakeMKV debug logs are over-written each time you start the program, so you have to copy them to a different name after you close, but before you restart, MakeMKV, if you want to save them.
Maybe someone who has already ripped this series can say if they had the same problem. My copy of Stargate Universe is on DVD, not BD.
suprkain
Re: SG Universe S1 1 Episode out of 3 is corrupt
Post by suprkain » Wed Sep 20, 2017 2:34 pm
I am using Windows 10, sorry. So I'm looking through Event Viewer and I don't see anything about makemkv. I checked windows logs from applications, security, and system but nothing talks about makemkv. The only things that occur during the time of the last failed attempt was: UPdated Windows Defender status successfully to SECURITY_PRODUCT_STATE_ON, Windows Security auditing, Time-Service, and Kernel-General. I looked through each one but none made reference to makemkv.
Edit: I uninstalled and reinstalled and attached is the makeMKV log file.
Edit 2: Apparently I can't attach files so I'll just copy and paste it here:
Debug log started at Wed Sep 20 15:25:10 2017 , written by MakeMKV v1.10.7 win(x64-release)
001005:0000 MakeMKV v1.10.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\suprk/MakeMKV_log.txt
001003:0020 DEBUG: Code 117506114 at ^zSIN%YYEx$DwS:213131962
002004:0000 Error 'Internal error - Operation was cancelled (66)' occurred while issuing SCSI command 460200010..00100 to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 0 at 's+Ay19T1\mWh,AL:121270214
001003:0020 DEBUG: Code 0 at 's+Ay19T1\mWh,AL:213135504
001003:0020 DEBUG: Code 0 at 's+Ay19T1\mWh,AL:121267247
Application exited at Wed Sep 20 15:26:58 2017
