Pumpkinhead 4 fails to open
farslayer9
Post by farslayer9 » Sat Sep 16, 2017 6:09 pm
When trying to open either an ISO or the disc, MKV fails to open. ANyone experience this who might have a solution?
Re: Pumpkinhead 4 fails to open
Post by Woodstock » Sat Sep 16, 2017 7:41 pm
"My car doesn't work. Any ideas?"
Without more information, that's what your request is.
What error messages are you getting? The FAQ in my signature is a good place to start for help, with turning on debug logging.
farslayer9
Post by farslayer9 » Sat Sep 16, 2017 7:51 pm
Here's the log file contents:
Debug log started at Sat Sep 16 19:46:02 2017 , written by MakeMKV v1.10.7 win(x64-release)
001005:0000 MakeMKV v1.10.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Administrator/MakeMKV_log.txt
003002:0000 Calculated BUP offset for VTS #0 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #3 does not match one in IFO header.
Application exited at Sat Sep 16 19:46:38 2017
Post by Woodstock » Sat Sep 16, 2017 11:06 pm
Those errors are consistent with problems reading the directory of the disk. Have you cleaned it?
farslayer9
Post by farslayer9 » Sun Nov 19, 2017 1:51 pm
I'm actually reading a data file, it's an ISO that I made of my disc so that I could play it from my server, I'm now wanting to convert the main movie into an MKv.
Post by Woodstock » Sun Nov 19, 2017 4:23 pm
My suggestion is to follow the FAQ link in my signature, and send the information you can to support@makemkv.com for Mike to look at it. For the log portion, try opening the disk directly AND the ISO in the same log, so Mike has more information.
