Branched titles + Dolby Atmos = dropouts
Meister_Proper
Post by Meister_Proper » Sun Jul 09, 2017 7:35 pm
In general makemkv works well with branched titles and reducing the audio skew. However, I have two movies where I do get audible dropouts in sound.
The first one is "Now You See Me 2 (2016) US":
AV sync issue in stream 1 at 0:10:29.545 with duration of 0.83ms : encountered overlapping frame, audio skew is +1.661ms
AV sync issue in stream 1 at 0:10:29.546 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.827ms
AV sync issue in stream 1 at 0:40:10.115 with duration of 0.83ms : encountered overlapping frame, audio skew is +1.658ms
AV sync issue in stream 1 at 0:40:10.117 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.825ms
AV sync issue in stream 1 at 0:40:41.773 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 0:40:41.774 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0ms
AV sync issue in stream 1 at 0:43:52.505 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 0:50:51.882 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 0:50:51.883 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0ms
AV sync issue in stream 1 at 0:54:03.740 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 0:54:03.741 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0ms
AV sync issue in stream 1 at 1:04:38.834 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 1:05:15.745 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 1:05:15.746 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0ms
AV sync issue in stream 1 at 1:25:38.341 with duration of 0.83ms : encountered overlapping frame, audio skew is +1.658ms
AV sync issue in stream 1 at 1:25:38.343 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.825ms
The dropout occurs at 40:41. Only this one, the rest is perfectly fine.
The second one is "John Wick: Chapter 2 (2017) US":
AV sync issue in stream 2 at 0:04:02.784 with duration of 31.791ms : encountered overlapping frame, audio skew is +31.791ms
AV sync issue in stream 2 at 0:04:23.596 with duration of 19.541ms : encountered overlapping frame, audio skew is +51.333ms
AV sync issue in stream 2 at 0:04:23.648 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +19.333ms
AV sync issue in stream 1 at 0:04:23.597 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 0:04:23.598 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.166ms
AV sync issue in stream 2 at 0:05:00.800 with duration of 12.166ms : encountered overlapping frame, audio skew is +31.5ms
AV sync issue in stream 1 at 0:05:00.800 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 2 at 0:05:51.559 with duration of 24.958ms : encountered overlapping frame, audio skew is +56.458ms
AV sync issue in stream 2 at 0:05:51.616 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +24.458ms
AV sync issue in stream 2 at 0:28:52.605 with duration of 9.666ms : encountered overlapping frame, audio skew is +34.125ms
AV sync issue in stream 2 at 0:28:52.640 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +2.125ms
AV sync issue in stream 1 at 0:28:52.606 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 2 at 0:29:23.636 with duration of 9ms : encountered overlapping frame, audio skew is +11.125ms
AV sync issue in stream 1 at 0:29:23.637 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 2 at 0:29:50.246 with duration of 14.083ms : encountered overlapping frame, audio skew is +25.208ms
AV sync issue in stream 1 at 0:29:50.247 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 2 at 0:31:46.905 with duration of 13.791ms : encountered overlapping frame, audio skew is +39ms
AV sync issue in stream 2 at 0:31:46.944 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +7ms
AV sync issue in stream 1 at 0:31:46.905 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 0:31:46.906 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.166ms
AV sync issue in stream 2 at 0:32:12.472 with duration of 0.791ms : encountered overlapping frame, audio skew is +7.791ms
AV sync issue in stream 2 at 0:52:34.651 with duration of 28.708ms : encountered overlapping frame, audio skew is +36.5ms
AV sync issue in stream 2 at 0:52:34.688 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +4.5ms
AV sync issue in stream 1 at 0:52:34.652 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.166ms
AV sync issue in stream 2 at 0:53:06.558 with duration of 29.125ms : encountered overlapping frame, audio skew is +33.625ms
AV sync issue in stream 2 at 0:53:06.592 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +1.625ms
AV sync issue in stream 2 at 0:54:00.153 with duration of 4.791ms : encountered overlapping frame, audio skew is +6.416ms
AV sync issue in stream 1 at 0:54:00.154 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
Audio dropout at 4:23. Again, just this single audible dropout.
I remuxed them several times and used the latest makemkv version. Playback was on PCH A-500 PRO.
Is there any way Mike can improve on the seamless branching plus Atmos?
I don't remember having this problem with TrueHD, but I'm not sure. So it might be specific to Atmos. Anybody else noticing the same?
Last edited by Meister_Proper on Sat Sep 16, 2017 8:57 pm, edited 1 time in total.
Meister_Proper
Re: Branched titles + Dolby Atmos = droputs
Post by Meister_Proper » Sun Jul 16, 2017 7:31 pm
Nobody experienced the same on mentioned movies?
Meister_Proper
Post by Meister_Proper » Sat Sep 16, 2017 6:00 pm
Another movie with this issue is "Baywatch (2017) 2in1 (US)" (ext. cut) with one audible dropout @01:20:36.
I send Mike the dump file but so far I haven't heard back from him when I asked about a status update.
I really hope that he can fix this as this is the only problem makemkv has.
AV sync issue in stream 1 at 0:05:49.265 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 0:07:44.923 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 0:09:32.530 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.041ms
AV sync issue in stream 1 at 0:11:12.338 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 0:31:33.809 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.038ms
AV sync issue in stream 1 at 1:05:17.705 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 1:05:17.706 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.041ms
AV sync issue in stream 1 at 1:06:34.907 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 1:11:31.704 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 1:11:31.705 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.038ms
AV sync issue in stream 1 at 1:13:56.265 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 1:20:36.164 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 1:20:36.165 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.033ms
AV sync issue in stream 1 at 1:21:36.641 with duration of 0.833ms : 1 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 1:35:23.176 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.041ms
AV sync issue in stream 1 at 1:44:00.443 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.036ms
