MakeMKV v1.10.7 OSX10.6.8 Crash On Open
adolder
Post by adolder »
Hello!
Basic System Info:
MakeMKV v1.10.7
OSX 10.6.8
MacPro 3,1 2009 Desktop
24gb RAM
I just installed the latest MakeMKV on my system and it crashed on first run. Didn't even get a GUI or load a disc or file.
I ran disc utility and repaired permissions. I shutdown and did a new start of the system. I reloaded MakeMKV and it crashed again on start.
I deleted MakeMKV v1.10.7 and re-installed v1.10.6. Runs like a charm, in fact as I write this post the program is doing its thing.
I saved the crash report from the OSX system logs. It appears to be a problem with MakeMKV v1.10.7 attempting to access RAM that is already allocated (that is my amateur sleuth interpretation of what I see in the crash report).
I have pasted the crash report below. Thank you in advance for any advice you can share.
Regards,
AD
*** Here is the crash:
Process: makemkv [773]
Path: /Applications/MakeMKV.app/Contents/MacOS/makemkv
Identifier: com.makemkv.MakeMKV
Version: v1.10.7 (0)
Code Type: X86-64 (Native)
Parent Process: launchd [140]
Date/Time: 2017-09-14 09:52:00.766 +0200
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 33643034 sec
Crashes Since Last Report: 764
Per-App Crashes Since Last Report: 1
Anonymous UUID: 88A12603-5F6D-49B1-992B-A72C995BC818
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libmqt.dylib 0x000000010682ffab QTreeWidget::clear() + 750347
1 libobjc.A.dylib 0x00007fff8a5940d6 call_load_methods + 391
2 libobjc.A.dylib 0x00007fff8a593d31 load_images + 220
3 dyld 0x00007fff5fc03166 dyld::notifySingle(dyld_image_states, ImageLoader const*) + 344
4 dyld 0x00007fff5fc0bced ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int) + 221
5 dyld 0x00007fff5fc0bcad ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int) + 157
6 dyld 0x00007fff5fc0bdb6 ImageLoader::runInitializers(ImageLoader::LinkContext const&) + 58
7 dyld 0x00007fff5fc0211a dyld::initializeMainExecutable() + 133
8 dyld 0x00007fff5fc06996 dyld::_main(macho_header const*, unsigned long, int, char const**, char const**, char const**) + 2993
9 dyld 0x00007fff5fc016de dyldbootstrap::start(macho_header const*, int, char const**, long) + 811
10 dyld 0x00007fff5fc01052 _dyld_start + 42
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x00007fff8a594ee4 rcx: 0x00007fffffe00080 rdx: 0x00000000ffffffff
rdi: 0x00007fff705b50e8 rsi: 0x0000000106b110d0 rbp: 0x00007fff5fbfd700 rsp: 0x00007fff5fbfd6f0
r8: 0x0000000106bfc0a0 r9: 0x0000000106bfc0a4 r10: 0x0000000000000018 r11: 0x0000000106b11140
r12: 0x0000000106b07a60 r13: 0x00007fff702d8d00 r14: 0x0000000106b110d0 r15: 0x0000000000000001
rip: 0x000000010682ffab rfl: 0x0000000000010246 cr2: 0x0000000000000000
Binary Images:
0x100000000 - 0x106304fff +com.makemkv.MakeMKV v1.10.7 (0) /Applications/MakeMKV.app/Contents/MacOS/makemkv
0x10631d000 - 0x106a3ffff +libmqt.dylib ??? (???) /Applications/MakeMKV.app/Contents/MacOS/libmqt.dylib
0x7fff5fc00000 - 0x7fff5fc3be0f dyld 132.1 (???) <29DECB19-0193-2575-D838-CF743F0400B2> /usr/lib/dyld
0x7fff80058000 - 0x7fff80059ff7 com.apple.TrustEvaluationAgent 1.1 (1) <5952A9FA-BC2B-16EF-91A7-43902A5C07B6> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff8005a000 - 0x7fff80170ff7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <3814FCF9-92B9-A6AB-E76A-F7021894AA3F> /usr/lib/libxml2.2.dylib
0x7fff80171000 - 0x7fff80192fe7 libPng.dylib ??? (???) <D8EC7740-EE32-865A-2F75-C9EDE2135510> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff80193000 - 0x7fff80199ff7 com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff801a6000 - 0x7fff80232fef SecurityFoundation ??? (???) <3F1F2727-C508-3630-E2C1-38361841FCE4> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff80299000 - 0x7fff8035afef com.apple.ColorSync 4.6.8 (4.6.8) <7DF1D175-6451-51A2-DBBF-40FCA78C0D2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff803ce000 - 0x7fff803eefff com.apple.DirectoryService.Framework 3.6 (621.16) <0ED4A74A-F8FB-366D-6588-F13EA397326F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff803ef000 - 0x7fff80412fff com.apple.opencl 12.3.6 (12.3.6) <42FA5783-EB80-1168-4015-B8C68F55842F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff80413000 - 0x7fff80413ff7 com.apple.Carbon 150 (152) <23704665-E9F4-6B43-1115-2E69F161FC45> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff80414000 - 0x7fff80b10ff7 com.apple.CoreGraphics 1.545.0 (???) <58D597B1-EB3B-710E-0B8C-EC114D54E11B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff80c16000 - 0x7fff80c3bff7 com.apple.CoreVideo 1.6.2 (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff80c3c000 - 0x7fff80cbbfe7 com.apple.audio.CoreAudio 3.2.6 (3.2.6) <79E256EB-43F1-C7AA-6436-124A4FFB02D0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff80d65000 - 0x7fff80e42fff com.apple.vImage 4.1 (4.1) <C3F44AA9-6F71-0684-2686-D3BBC903F020> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff80e82000 - 0x7fff80eecfe7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <AF0EA96D-000F-8C12-B952-CB7E00566E08> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff80f03000 - 0x7fff80fb3fff edu.mit.Kerberos 6.5.11 (6.5.11) <085D80F5-C9DC-E252-C21B-03295E660C91> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff80fc0000 - 0x7fff80fd1ff7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <97019C74-161A-3488-41EC-A6CA8738418C> /usr/lib/libz.1.dylib
0x7fff8109e000 - 0x7fff810fefe7 com.apple.framework.IOKit 2.0 (???) <4F071EF0-8260-01E9-C641-830E582FA416> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff81115000 - 0x7fff81118ff7 com.apple.securityhi 4.0 (36638) <AEF55AF1-54D3-DB8D-27A7-E16192E0045A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff81164000 - 0x7fff81166fff com.apple.print.framework.Print 6.1 (237.1) <CA8564FB-B366-7413-B12E-9892DA3C6157> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff81167000 - 0x7fff81167ff7 com.apple.CoreServices 44 (44) <DC7400FB-851E-7B8A-5BF6-6F50094302FB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff81168000 - 0x7fff8123cfe7 com.apple.CFNetwork 454.12.4 (454.12.4) <C83E2BA1-1818-B3E8-5334-860AD21D1C80> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff8123f000 - 0x7fff81295fe7 libTIFF.dylib ??? (???) <2DBEC120-DAA7-3789-36A2-A205BCDF2D72> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff81760000 - 0x7fff8177bff7 com.apple.openscripting 1.3.1 (???) <9D50701D-54AC-405B-CC65-026FCB28258B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff8177c000 - 0x7fff8193bfff com.apple.ImageIO.framework 3.0.6 (3.0.6) <92882FD3-CB3F-D0BE-DDDA-43B4BEE10F58> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff8193c000 - 0x7fff81941fff libGFXShared.dylib ??? (???) <6BBC351E-40B3-F4EB-2F35-05BDE52AF87E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff81942000 - 0x7fff81a61ff7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <0CE8D59B-D0C7-1DCE-3654-37F27F61BEFA> /usr/lib/libcrypto.0.9.8.dylib
0x7fff81a62000 - 0x7fff81a6dff7 com.apple.speech.recognition.framework 3.11.1 (3.11.1) <3D65E89B-FFC6-4AAF-D5CC-104F967C8131> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff81a6e000 - 0x7fff81ab6ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <98FC4457-F405-0262-00F7-56119CA107B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff81acb000 - 0x7fff81acbff7 com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff81acc000 - 0x7fff81accff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <4CCE5D69-F1B3-8FD3-1483-E0271DB2CCF3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff81acd000 - 0x7fff81ae1fff libGL.dylib ??? (???) <2ECE3B0F-39E1-3938-BF27-7205C6D0358B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff81ae2000 - 0x7fff824dcff7 com.apple.AppKit 6.6.8 (1038.36) <4CFBE04C-8FB3-B0EA-8DDB-7E7D10E9D251> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff82535000 - 0x7fff825d5fff com.apple.LaunchServices 362.3 (362.3) <B90B7C31-FEF8-3C26-BFB3-D8A48BD2C0DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff8291d000 - 0x7fff82921ff7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
0x7fff82957000 - 0x7fff8299eff7 com.apple.coreui 2 (114) <923E33CC-83FC-7D35-5603-FB8F348EE34B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff82a52000 - 0x7fff82a68fef libbsm.0.dylib ??? (???) <42D3023A-A1F7-4121-6417-FCC6B51B3E90> /usr/lib/libbsm.0.dylib
0x7fff82a69000 - 0x7fff82a6bfff libRadiance.dylib ??? (???) <BF694EE5-6FDA-553A-CC89-F7135618E9C7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff82a6c000 - 0x7fff82c2dfef libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
0x7fff82cd0000 - 0x7fff82ce2fe7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
0x7fff82cef000 - 0x7fff82d3bfff libauto.dylib ??? (???) <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib
0x7fff82ead000 - 0x7fff8312ffff com.apple.Foundation 6.6.8 (751.63) <E10E4DB4-9D5E-54A8-3FB6-2A82426066E4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff83130000 - 0x7fff832a7fe7 com.apple.CoreFoundation 6.6.6 (550.44) <BB4E5158-E47A-39D3-2561-96CB49FA82D4> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff832ee000 - 0x7fff83319ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <3630A97F-55C1-3F34-CA63-3847653C9645> /usr/lib/libxslt.1.dylib
0x7fff8331a000 - 0x7fff833cffe7 com.apple.ink.framework 1.3.3 (107) <8C36373C-5473-3A6A-4972-BC29D504250F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff833d0000 - 0x7fff836cefff com.apple.HIToolbox 1.6.5 (???) <AD1C18F6-51CB-7E39-35DD-F16B1EB978A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff836cf000 - 0x7fff83a03fef com.apple.CoreServices.CarbonCore 861.39 (861.39) <1386A24D-DD15-5903-057E-4A224FAF580B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff83a4c000 - 0x7fff83a5bfff com.apple.NetFS 3.2.2 (3.2.2) <7CCBD70E-BF31-A7A7-DB98-230687773145> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff83afa000 - 0x7fff83afdff7 libCoreVMClient.dylib ??? (???) <75819794-3B7A-8944-D004-7EA6DD7CE836> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff83cdc000 - 0x7fff83e1afff com.apple.CoreData 102.1 (251) <9DFE798D-AA52-6A9A-924A-DA73CB94D81A> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff84008000 - 0x7fff84098fff com.apple.SearchKit 1.3.0 (1.3.0) <4175DC31-1506-228A-08FD-C704AC9DF642> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff84099000 - 0x7fff840adff7 com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <621B7415-A0B9-07A7-F313-36BEEDD7B132> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff84194000 - 0x7fff84211fef libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
0x7fff84212000 - 0x7fff84253fff com.apple.SystemConfiguration 1.10.8 (1.10.2) <78D48D27-A9C4-62CA-2803-D0BBED82855A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff84279000 - 0x7fff842a0ff7 libJPEG.dylib ??? (???) <08758593-6436-B29E-1DA8-F15597835EC1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff842b6000 - 0x7fff8433bff7 com.apple.print.framework.PrintCore 6.3 (312.7) <CDFE82DD-D811-A091-179F-6E76069B432D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff8509e000 - 0x7fff8509eff7 com.apple.vecLib 3.6 (vecLib 3.6) <96FB6BAD-5568-C4E0-6FA7-02791A58B584> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff8509f000 - 0x7fff85161fe7 libFontParser.dylib ??? (???) <EF06F16C-0CC9-B4CA-7BD9-0A97FA967340> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff85203000 - 0x7fff85212fef com.apple.opengl 1.6.14 (1.6.14) <ECAE2D12-5BE3-46E7-6EE5-563B80B32A3E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff85213000 - 0x7fff85266ff7 com.apple.HIServices 1.8.3 (???) <F6E0C7A7-C11D-0096-4DDA-2C77793AA6CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff8528f000 - 0x7fff85296fff com.apple.OpenDirectory 10.6 (10.6) <4FF6AD25-0916-B21C-9E88-2CC42D90EAC7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff85297000 - 0x7fff85455fff libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <97A75BFB-0DB6-6F44-36B0-97B7F7208ABB> /usr/lib/libicucore.A.dylib
0x7fff855dc000 - 0x7fff85626ff7 com.apple.Metadata 10.6.3 (507.15) <DE238BE4-5E22-C4D5-CF5C-3D50FDEE4701> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff858d3000 - 0x7fff85904fff libGLImage.dylib ??? (???) <562565E1-AA65-FE96-13FF-437410C886D0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff85a11000 - 0x7fff85b09ff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <44AADE50-15BC-BC6B-BEF0-5029A30766AC> /usr/lib/libiconv.2.dylib
0x7fff85b16000 - 0x7fff85b94ff7 com.apple.CoreText 151.13 (???) <5C6214AD-D683-80A8-86EB-328C99B75322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff85e27000 - 0x7fff85e40fff com.apple.CFOpenDirectory 10.6 (10.6) <401557B1-C6D1-7E1A-0D7E-941715C37BFA> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff85e5c000 - 0x7fff86666fe7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <FC941ECB-71D0-FAE3-DCBF-C5A619E594B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff86790000 - 0x7fff86795ff7 com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff86796000 - 0x7fff8687bfef com.apple.DesktopServices 1.5.11 (1.5.11) <39FAA3D2-6863-B5AB-AED9-92D878EA2438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff8687c000 - 0x7fff86c19fe7 com.apple.QuartzCore 1.6.3 (227.37) <16DFF6CD-EA58-CE62-A1D7-5F6CE3D066DD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff86c1a000 - 0x7fff86d34fff libGLProgrammability.dylib ??? (???) <D1650AED-02EF-EFB3-100E-064C7F018745> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff86d35000 - 0x7fff86d6ffff libcups.2.dylib 2.8.0 (compatibility 2.0.0) <4F2A4397-89BD-DEAC-4971-EE838FFA0964> /usr/lib/libcups.2.dylib
0x7fff87325000 - 0x7fff8732cfef com.apple.CommerceCore 1.0 (9.2) <71BA8AF7-A99D-4862-CDE1-AA67D90B6067> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fff8732d000 - 0x7fff87462fff com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <F4814A13-E557-59AF-30FF-E62929367933> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff876ce000 - 0x7fff876d1fff com.apple.help 1.3.2 (41.1) <BD1B0A22-1CB8-263E-FF85-5BBFDE3660B9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff8771e000 - 0x7fff87773ff7 com.apple.framework.familycontrols 2.0.2 (2020) <8807EB96-D12D-8601-2E74-25784A0DE4FF> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7fff877b8000 - 0x7fff877bdfff libGIF.dylib ??? (???) <3BAD0DE8-8151-68B0-2244-A4541C738972> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff8784c000 - 0x7fff87874fff com.apple.DictionaryServices 1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff87875000 - 0x7fff87896fff libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <9410EC7F-4D24-6740-AFEE-90405750FAD7> /usr/lib/libresolv.9.dylib
0x7fff879a8000 - 0x7fff87debfef libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <0CC61C98-FF51-67B3-F3D8-C5E430C201A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff882f3000 - 0x7fff88334fef com.apple.QD 3.36 (???) <5DC41E81-32C9-65B2-5528-B33E934D5BB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff88335000 - 0x7fff883f2fff com.apple.CoreServices.OSServices 359.2 (359.2) <BBB8888E-18DE-5D09-3C3A-F4C029EC7886> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff883f3000 - 0x7fff8842efff com.apple.AE 496.5 (496.5) <208DF391-4DE6-81ED-C697-14A2930D1BC6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff884ad000 - 0x7fff884c3fe7 com.apple.MultitouchSupport.framework 207.11 (207.11) <8233CE71-6F8D-8B3C-A0E1-E123F6406163> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff8953a000 - 0x7fff8954fff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <1AE1FE8F-2204-4410-C94E-0E93B003BEDA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff89550000 - 0x7fff8955eff7 libkxld.dylib ??? (???) <8145A534-95CC-9F3C-B78B-AC9898F38C6F> /usr/lib/system/libkxld.dylib
0x7fff89571000 - 0x7fff89572ff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <49B723D1-85F8-F86C-2331-F586C56D68AF> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff89e0b000 - 0x7fff89e54fef libGLU.dylib ??? (???) <B0F4CA55-445F-E901-0FCF-47B3B4BAE6E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff89f0d000 - 0x7fff89f0efff liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
0x7fff89f2b000 - 0x7fff8a1b4ff7 com.apple.security 6.1.2 (55002) <D224882B-D57B-83AF-3781-548BCEACB327> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff8a1e1000 - 0x7fff8a230ff7 com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <0731C40D-71EF-B417-C83B-54C3527A36EA> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x7fff8a521000 - 0x7fff8a527ff7 IOSurface ??? (???) <8E302BB2-0704-C6AB-BD2F-C2A6C6A2E2C3> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff8a528000 - 0x7fff8a53ffff com.apple.ImageCapture 6.1 (6.1) <79AB2131-2A6C-F351-38A9-ED58B25534FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff8a590000 - 0x7fff8a646ff7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <03140531-3B2D-1EBA-DA7F-E12CC8F63969> /usr/lib/libobjc.A.dylib
0x7fff8a647000 - 0x7fff8a700fff libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150> /usr/lib/libsqlite3.dylib
0x7fff8a701000 - 0x7fff8a701ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <15DF8B4A-96B2-CB4E-368D-DEC7DF6B62BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff8a702000 - 0x7fff8a79cfff com.apple.ApplicationServices.ATS 275.19 (???) <2DE8987F-4563-4D8E-45C3-2F6F786E120D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fffffe00000 - 0x7fffffe01fff libSystem.B.dylib ??? (???) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
Model: MacPro3,1, BootROM MP31.006C.B05, 8 processors, Quad-Core Intel Xeon, 2.8 GHz, 24 GB, SMC 1.25f4
Graphics: ATI Radeon HD 5770, ATI Radeon HD 5770, PCIe, 1024 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x88), Broadcom BCM43xx 1.0 (5.10.131.42.4)
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: Ethernet 1, Ethernet, en0
PCI Card: ATI Radeon HD 5770, sppci_displaycontroller, Slot-2
PCI Card: ATI Radeon HD 5770, ATY,HoolockParent, Slot-2
Serial ATA Device: ST3000DM001-1CH166, 2.73 TB
Serial ATA Device: ST3000DM001-9YN166, 2.73 TB
Serial ATA Device: HL-DT-ST BD-RE WH12LS39
Parallel ATA Device: OPTIARC DVD RW AD-7170A
USB Device: Keyboard Hub, 0x05ac (Apple Inc.), 0x1006, 0xfd500000 / 2
USB Device: Apple Keyboard, 0x05ac (Apple Inc.), 0x0220, 0xfd520000 / 3
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8206, 0x5d200000 / 2
USB Device: PTZ-630, 0x056a (WACOM Co., Ltd.), 0x00b1, 0x3d100000 / 2
FireWire Device: Voyager Q, 0x30E0, Up to 800 Mb/sec
FireWire Device: built-in_hub, Up to 800 Mb/sec
FireWire Device: unknown_device, Unknown
