life of brian DVD
cactus128
life of brian DVD
Post by cactus128 »
I have just tried to convert my copy of monty pythons life of brian (2007) into an MKV so that i can use it on my WDTV.
It crashes the program completely whilst carrying out its scan of the disk, have tried to use DVD shrink and DVD decrypter to break the protection first, but they fail also.
I thought i would flag this up, as maybe it is not known about.
Cheers,
Rob
setarip_old
Re: life of brian DVD
Post by setarip_old »
Hi!
That 2007/2008 version ("Immaculate") was released by SONY - and, as such, the only additional copy protection it would have would be SONY's "ARccOS", which MakeMKV should readily handle.
Try holding and keeping down the "Shift" key while loading the original, commercial disc.
Have you checked to see if:
1) The original, commercial disc plays properly on your PC, and
2) If the original, commercial disc is soiled, scratched, or otherwise physically damaged?
crowfax
Post by crowfax »
cactus128
Post by cactus128 »
Debug log started at Mon May 31 11:39:09 2010 , written by MakeMKV v1.5.6 beta win(x86-release)
Using 523392KB for read cache.
001005:0000 MakeMKV v1.5.6 beta win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Rob/MakeMKV_log.txt
003033:0000 Cell 1 was discarded (structure protection?)
001003:0020 DEBUG: Code 10551308 at }&*]):<OSOt&"@_-;#W:29399036
001003:0020 DEBUG: Code 0 at Z<]H0NQRw\@}""eh<':213130375
003035:0000 CellWallk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
003037:0000 Cells 1-23 were removed form title start
003038:0000 Cells 78-78 were removed form title end
003033:0000 Cell 67 was discarded (structure protection?)
003033:0000 Cell 68 was discarded (structure protection?)
003028:0000 Title #0 was added (54 cell(s), 1:29:35)
003025:0000 Title #1 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #5 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #9 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #10 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #11 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #12 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #13 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #14 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #15 has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
003033:0000 Cell 2 was discarded (structure protection?)
003033:0000 Cell 3 was discarded (structure protection?)
003033:0000 Cell 4 was discarded (structure protection?)
003033:0000 Cell 5 was discarded (structure protection?)
003033:0000 Cell 6 was discarded (structure protection?)
003033:0000 Cell 7 was discarded (structure protection?)
003033:0000 Cell 8 was discarded (structure protection?)
003033:0000 Cell 9 was discarded (structure protection?)
003033:0000 Cell 10 was discarded (structure protection?)
003033:0000 Cell 11 was discarded (structure protection?)
003033:0000 Cell 12 was discarded (structure protection?)
003033:0000 Cell 13 was discarded (structure protection?)
003033:0000 Cell 14 was discarded (structure protection?)
003033:0000 Cell 15 was discarded (structure protection?)
003033:0000 Cell 16 was discarded (structure protection?)
003033:0000 Cell 17 was discarded (structure protection?)
003033:0000 Cell 18 was discarded (structure protection?)
003033:0000 Cell 19 was discarded (structure protection?)
003033:0000 Cell 20 was discarded (structure protection?)
003033:0000 Cell 21 was discarded (structure protection?)
003033:0000 Cell 22 was discarded (structure protection?)
003033:0000 Cell 23 was discarded (structure protection?)
003033:0000 Cell 24 was discarded (structure protection?)
003033:0000 Cell 25 was discarded (structure protection?)
003033:0000 Cell 26 was discarded (structure protection?)
003033:0000 Cell 27 was discarded (structure protection?)
003033:0000 Cell 28 was discarded (structure protection?)
003033:0000 Cell 29 was discarded (structure protection?)
003033:0000 Cell 30 was discarded (structure protection?)
003033:0000 Cell 31 was discarded (structure protection?)
003033:0000 Cell 32 was discarded (structure protection?)
003033:0000 Cell 33 was discarded (structure protection?)
001003:0020 DEBUG: Code 0 at JcTY?F-,)PT|(Hin:29398277
001003:0020 DEBUG: Code 117572226 at h2J^\8xh[TOk[#8}B8:29394137
003033:0000 Cell 69 was discarded (structure protection?)
003033:0000 Cell 70 was discarded (structure protection?)
003033:0000 Cell 71 was discarded (structure protection?)
003033:0000 Cell 72 was discarded (structure protection?)
003033:0000 Cell 73 was discarded (structure protection?)
003033:0000 Cell 74 was discarded (structure protection?)
003033:0000 Cell 75 was discarded (structure protection?)
003033:0000 Cell 76 was discarded (structure protection?)
003033:0000 Cell 77 was discarded (structure protection?)
001003:0020 DEBUG: Code 4 at }&*]):<OSOt&"@_-;#W:213136010
003033:0000 Cell 78 was discarded (structure protection?)
001003:0020 DEBUG: Code 0 at uVf+1`<gtH]:Qr?gx:121263153
001003:0020 DEBUG: Code 0 at uVf+1`<gtH]:Qr?gx:29395172
001003:0020 DEBUG: Code 765057 at Z<]H0NQRw\@}""eh<':121264671
001003:0020 DEBUG: Code 0 at Z<]H0NQRw\@}""eh<':29400830
001003:0020 DEBUG: Code 0 at Z<]H0NQRw\@}""eh<':213137712
003015:0000 Title #19 (1:29:57) was skipped due to navigation error
001003:0020 DEBUG: Code 0 at Z<]H0NQRw\@}""eh<':121266373
001003:0020 DEBUG: Code 899 at RiZGf)9&N;%v +;(|UG{':29395747
001003:0020 DEBUG: Code 0 at m2r*|dy|*;"4<SRI[]F:213130858
vobs=ZeNpjYBgFo2AUjIJRMApGwUgDAAgAAAE=
001003:0020 DEBUG: Code 0 at m2r*|dy|*;"4<SRI[]F:29393861
001003:0020 DEBUG: Code 0 at |wKwUdg[dL Yb[[<#|$;:29394413
001003:0020 DEBUG: Code 82 at |wKwUdg[dL Yb[[<#|$;:213129639
001003:0020 DEBUG: Code 1 at Z<]H0NQRw\@}""eh<':213139782
001003:0020 DEBUG: Code 2 at Z<]H0NQRw\@}""eh<':213139782
001003:0020 DEBUG: Code 579 at RiZGf)9&N;%v +;(|UG{':29395747
001003:0020 DEBUG: Code 3 at Z<]H0NQRw\@}""eh<':213139782
001003:0020 DEBUG: Code 4 at Z<]H0NQRw\@}""eh<':213139782
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory C:/Users/Rob/Desktop
001003:0020 DEBUG: Code 0 at |wKwUdg[dL Yb[[<#|$;:213130513
001003:0020 DEBUG: Code 0 at RiZGf)9&N;%v +;(|UG{':29397449
001003:0020 DEBUG: Code 0 at @YPizs45[New~G>}yf|:29395379
001003:0020 DEBUG: Code 0 at @YPizs45[New~G>}yf|:121261888
FS ID=V_MPEG2 C=1
C_00000=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
001003:0020 DEBUG: Code 0 at @YPizs45[New~G>}yf|:29393838
001003:0020 DEBUG: Code 0 at RiZGf)9&N;%v +;(|UG{':121265775
001003:0020 DEBUG: Code 0 at c_e5kB8s QzOW_)/e?a:213130490
001003:0020 DEBUG: Code 0 at c_e5kB8s QzOW_)/e?a:121263567
005003:0000 Failed to save title 0 to file C:/Users/Rob/Desktop/t00_Life_of_Brian.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Mon May 31 11:40:28 2010
here is the log file that i generated from the latest version of make mkv.
it scans the disk then when i go to write the mkv it fails immediately.
rob
cactus128
Post by cactus128 »
if it makes any differnece, the edition that i have is the 2-disc collectors edition
crowfax
Post by crowfax »
cactus128 wrote:if it makes any differnece, the edition that i have is the 2-disc collectors edition
Did you email the log file and IFO's from the disc to support@makemkv.com ?
setarip_old
@cactu128
Again, have you done the following?:
