Argo BLu Ray, extra's but no movie
Mr Grumpy
#1 Post by Mr Grumpy » Sat Sep 09, 2017 5:58 am
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00030.m2ts' at offset '129024'
Title #00030.m2ts was skipped
Protection: AACS v31
I have been trying to rip Argo Extended Cut with MakeMKV v1.10.7. While it does find all the extra's included on the disc, it won't find the actual movie.
I use a Pioneer BD-RE BDR-208D 1.10 for ripping my disks.
Hope you will be able to find a solution for this. Thanks.
Re: Argo BLu Ray, extra's but no movie
#2 Post by Woodstock » Sat Sep 09, 2017 11:13 am
Have you tried cleaning the disk?
You have at least one spot, which corresponds with where the movie's files are located, that your drive cannot read. The most likely cause is a contaminated or damaged surface. Since it appears to have happened during the scan phase, it is probably near the hub of the disk, where directory information is stored..
