FUT errors on My Cousin Rachel blu-ray
stuckinkodiagain
Post by stuckinkodiagain »
I'm getting FUT errors on the blu-ray for "My Cousin Rachel," released just this week.
I've submitted the dump file and log to both support@makemkv.com and svq@makemkv.com.
Thanks for your help!
stuckinkodiagain
Re: FUT errors on My Cousin Rachel blu-ray
Anyone who's interested in this disc please note that the latest version of MakeMKV (1.10.7) does not fix this issue, but the devs ARE working on it.
ekael86
Post by ekael86 »
Dump file sent as well.
stuckinkodiagain
Developer has updated the SVQ files for "My Cousin Rachel," which fixes the FUT errors. No more pixellated video! (Please note that you'll need an active internet connection when you scan the disc to get the new SVQ's.)
Thanks, guys! Works great!
ekael86
Post by ekael86 »
Works Perfect. Thanks!
dillspooch
Post by dillspooch »
This isn't working for me. I'm running MakeMKV v1.10.8, have an active internet connection and in the preferences dialog box, and the 'allow contacting web server for updates' is turned on. I'm getting FUT errors on my disc.
I'm in the UK. The disc has a code on it: F1-69835-BD-SE. Could my version of the Blu Ray disc be different from the original poster's disc?
Did you send the file MakeMKV generated to svq@makemkv.com as indicated in the log window? If your version isn't working with the revised fix-up, Mike will need to see that dump file to update the SVQ.
