I tried to rip "Nikita", italian blu ray, but appears always an error of "failed" after about 1,3 Giga. I use the latest version 1.10.6 and this is the first time that happen.
Please help me.
Thank you very much.
Error ripping "Nikita" Italian blu ray
Re: Error ripping "Nikita" Italian blu ray
Make sure you have debug logging enabled (information found in the FAQ link in my signature). We need information about WHY it failed, which will usually appear in the log.
Also, check this topic: http://makemkv.com/forum2/viewtopic.php?f=8&t=15055
Thank you, I've sent an email to support with the log file and the other files zipped. I await a kind reply. Thank you again.
Hello, I wrote to support of MakeMkv but I haven't still received any answer. Anyone can help me? Why support don't answer? Thanks a lot.
Writing to support@makemkv.com is the most direct line to the developer, Mike. He doesn't visit the forum as much as we users would like.
Can you copy some of the errors from the log into a message here, and we can see if they're ones we have experienced?
Hello Woodstock,
thank you very much for your help, thank you for showing interest in my problem and answering my request for help. Thank you very much.
Here is the entire final log report, I did not know what to choose and in the end I think it's better that you read it all.
Debug log started at Wed Aug 23 20:35:41 2017 , written by MakeMKV v1.10.6 darwin(x86-release)
Using 1048320KB for read cache.
001005:0000 MakeMKV v1.10.6 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/Ale/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL HL-DT-ST DVDRW GA32N KC12d" opened in OS access mode.
002010:0000 Optical drive "BD-RE PIONEER BD-RW BDR-UD03 1.05d" opened in OS access mode.
DEBUG: Code 2147483648 at cK].1U./Kcz9aOR):121265315
DAFD=PAAAADAAAAEABDQkEGwEBAQ==
DCE=8l8jE8w+9/I/ElmII4dzPPKEGockan+aHBAroDjDd8CKJYbkUmoXsaaPC1jh4wsBFzzzSYi1VygwCY/8xqy35VKPnNGw6ZyhKb14Z2esHmERpsJcNWdpFlamrYdegV1NcE6no9j2WMpAHWCdpq9a3bRTwK1B45z2cQ==
DCE=mvR0RSqXjuCFNx8u1C7eRnyUuSGh5in1Rp1hNOzqL8n75DyJRwFft0gu+H1SsMH0SziP3DFa/wW8oGqp4MbW88ldAtJBz12Agv8grQDuyXQELFhgkABoYXDdhkAswYN2n6cPwlLONewPunwuQDF5sXBKmzz6w2z+/A==
DISCID=0E7D3EDA802900ABFBE99893C3C1674C9E4B736E
003307:0000 File 00003.mpls was added as title #0
003307:0000 File 00001.m2ts was added as title #1
003307:0000 File 00000.m2ts was added as title #2
003307:0000 File 00003.m2ts was added as title #3
003307:0000 File 00002.m2ts was added as title #4
005014:0000 Saving 1 titles into directory /Volumes/Avvio esterno/Appoggio/Nikita
001003:0020 DEBUG: Code 6557 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 118080 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 6563 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 115188 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 6857 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 117480 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 6863 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 114588 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 7109 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 128016 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 7115 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 125124 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 7299 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 128436 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 7305 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 125544 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 7451 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 131172 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 7619 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 134196 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 7769 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 133896 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 7817 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 134760 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 8027 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 141540 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 8297 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 143400 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 8477 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 152640 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 8667 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 153060 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 8765 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 157824 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 8771 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 154932 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 8903 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 151308 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 8909 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 160416 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 9057 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 157080 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 9129 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 158376 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 9219 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 162996 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 10167 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 174060 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 10317 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 185760 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 10355 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 183444 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 10541 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 189792 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 10727 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 184140 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 10911 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 187452 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 11107 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 196980 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 11209 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 195816 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 11287 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 194220 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 11335 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 195084 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 11531 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 204612 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 11671 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 201132 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 11749 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 211536 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 11849 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 207336 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 12025 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 210504 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 12185 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 213384 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 12403 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 220308 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 12467 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 221460 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 14545 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 255864 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 14653 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 263808 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 14659 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 260916 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 14839 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 258156 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 15755 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 280644 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 15967 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 278460 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 16681 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 294312 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 16813 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 302688 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 20081 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 355512 at 0K3q=&H9;9AV%g6eS~p:121266074
001003:0020 DEBUG: Code 20231 at 0K3q=&H9;9AV%g6eS~p:213134262
001003:0020 DEBUG: Code 355212 at 0K3q=&H9;9AV%g6eS~p:121266074
001001:0020 DBG ASSERT: ,}W$VGL`2(F#]8E04:{_-8j at 4@F[kc#UA/>W6!@z:29395954
001001:0020 DBG ASSERT: ,}W$VGL`2(F#]8E04:{_-8j at nm<^QIS|WwJyX^@Zc:29396368
001002:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
004007:0010 AV synchronization issues were found in file '/Volumes/Avvio esterno/Appoggio/Nikita/Nikita_t00.mkv' (title #1)
004047:0010 AV sync issue in stream 0 at 4744532:49:19.761 : video frame timecode differs by +854.015s
004047:0010 AV sync issue in stream 0 at 4744532:49:19.803 : video frame timecode differs by +854.015s
004047:0010 AV sync issue in stream 0 at 4744532:49:19.886 : video frame timecode differs by +854.015s
004047:0010 AV sync issue in stream 0 at 4744532:49:19.845 : video frame timecode differs by +854.015s
004047:0010 AV sync issue in stream 0 at 4744532:49:19.970 : video frame timecode differs by +854.015s
004047:0010 AV sync issue in stream 0 at 4744532:49:19.928 : video frame timecode differs by +854.015s
004047:0010 AV sync issue in stream 0 at 4744532:49:20.053 : video frame timecode differs by +854.015s
004047:0010 AV sync issue in stream 0 at 4744532:49:20.011 : video frame timecode differs by +854.015s
004047:0010 AV sync issue in stream 0 at 4744532:49:20.137 : video frame timecode differs by +854.015s
004047:0010 AV sync issue in stream 0 at 4744532:49:20.095 : video frame timecode differs by +854.015s
004047:0010 AV sync issue in stream 0 at 4744532:49:20.095 : too many video frames with invalid timecodes, future messages will be suppressed
005003:0000 Failed to save title 0 to file /Volumes/Avvio esterno/Appoggio/Nikita/Nikita_t00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Wed Aug 23 20:39:01 2017Re: Error ripping "Nikita" Italian blu ray
The large number of debug messages is consistent with the drive not QUITE being able to read the disk in some areas.
Unfortunately, some drives do not issue error messages if they can "mostly" read a disk. Rather than say that the data is "bad", they return what they were able to recover. MakeMKV sees the inconsistency, and tries different work-arounds (announced by the DEBUG:Code messages) to make the data work. If it cannot, it fails the save.
Since Mike has the means to decode what each debug message means, he's the final authority on what other information he will need from you, but... Have you checked out this topic yet? http://makemkv.com/forum2/viewtopic.php?f=8&t=15055
Thank you for your answer. I've seen the topic you suggested me, but I don't find anything useful to resolve my problem.
Is it possible that Mike answer to my mail I've sent to support more than a week ago?
Thank you.
Thank you.
I have no control over Mike's responses - we aren't even on the same continent. Sorry.
The reason I suggested the other topic is that the majority of "new copy protection!" messages here turn out to be "dirty disk errors". No one ever believes that a brand new, fresh from the package disk can be "dirty", because it "looks flawless", but that is still the #1 cause of read errors.
Dear Woodstock,
thank you very much for your answer.
MakeMkv support team wrote me today and they said that a new version of the software could solve the problem.
I've downloaded and installed the 1.10.7 version and everything is gone well.
The disc was ripped perfectly.
Thank you very very much for your precious help, I really appreciated your attention for my problem.
harold1967
I have a BDR-UD03 Verbatim / Pioneer drive. Can find FW its on FW 1.10. Can you please assist me with UHD firmware please?
Current profile: BD-R SRM
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.10
Serial number:
Firmware date: 2017-04-18
Drive platform: RS8511
Firmware version: 1.10
Revision: 1.10
Serial number:
