A few months ago I installed MAKEMKV 1.10.5.1 in Ubuntu 16.04 using
sudo add-apt-repository ppa:heyarje/makemkv-beta
sudo apt-get update
sudo apt-get install makemkv-bin makemkv-oss
I now want to upgrade to 1.10.6 and downloaded
/download/makemkv-bin-1.10.6.tar.gz
/download/makemkv-oss-1.10.6.tar.gz
In which directory do I have to place the bin and oss tars in order to proceed
with the sudo make install for the bin and tar packages ?
installing makemkv 1.10.6
andreapetrucci
Re: installing makemkv 1.10.6
It doesn't matter where you put the tars, if your ubuntu-username is "YOURUSERNAME" then /home/YOURUSERNAME will be fine.newbie45 wrote:A few months ago I installed MAKEMKV 1.10.5.1 in Ubuntu 16.04 using
sudo apt-get update
General instructions are here:http://www.makemkv.com/forum2/viewtopic.php?f=3&t=224, in the forum you can find posts with distro-specific instructions and tips.
I hope it helps.
Thanks and sorry for my late reply, I will try this as soon as I have my system working again
thanks Andrea
I have now installed makemkv 1.10.6 and it's working fine
