Issues with "Vampire Diaries 7"
Tolotos
Post by Tolotos »
I got some issues with the Vampire Diaries 7 BD:
Die Quell-Datei ist defekt oder ungültig. Es wird versucht, dies zu umgehen
AV synchronization issues were found in file 'H:/MediaCenter/_inWork/Serie/The Vampire Diaries/disk 01/title00.mkv' (title #1)
AV sync issue in stream 0 at 0:00:05.463 : video frame timecode differs by +41.708ms
AV sync issue in stream 0 at 0:00:05.505 : video frame timecode differs by -41.711ms
AV sync issue in stream 0 at 0:00:07.549 : video frame timecode differs by +41.702ms
AV sync issue in stream 0 at 0:00:07.590 : video frame timecode differs by -41.716ms
AV sync issue in stream 0 at 0:00:15.724 : video frame timecode differs by +41.702ms
AV sync issue in stream 0 at 0:00:15.765 : video frame timecode differs by -41.716ms
AV sync issue in stream 0 at 0:00:19.019 : video frame timecode differs by +41.7ms
AV sync issue in stream 0 at 0:00:19.060 : video frame timecode differs by -41.708ms
AV sync issue in stream 0 at 0:00:21.730 : video frame timecode differs by +41.702ms
AV sync issue in stream 0 at 0:00:21.771 : video frame timecode differs by -41.716ms
AV sync issue in stream 0 at 0:00:21.771 : too many video frames with invalid timecodes, future messages will be suppressed
Erzwungener Untertitel #2 ist leer und wurde aus der Ausgabedatei entfernt
Erzwungener Untertitel #3 ist leer und wurde aus der Ausgabedatei entfernt
AV sync issue in stream 0 at 0:42:30.005 : video stream has 478 frames with invalid timecodes
... (for every episode)
The AV sync issue should be a minor problem but whats about the "Sourcefile broken or invalid" message?
-- Tolotos
EDIT: I'm using version 1.10.3 x64 win
EDIT2: Please move to the DB section :oops:
angelgraves13
Re: Issues with "Vampire Diaries 7"
Post by angelgraves13 »
Either it's mastered that way or it's a new type of copy protection that's circumvented.
Supergirl S1, and Legends of Tomorrow also does the same thing. They all play 100% correct.
Achilles
Post by Achilles »
Not sure why but using CloneBD by Elaborate Bytes allowed me to create MKVs with Supergirl and Legends of Tomorrow without the framerate stuttering due to
angelgraves13
Achilles wrote:Not sure why but using CloneBD by Elaborate Bytes allowed me to create MKVs with Supergirl and Legends of Tomorrow without the framerate stuttering due to
What does the created file say in the media player properties? I've heard CloneBD isn't half as good as MakeMKV.
Meister_Proper
Post by Meister_Proper »
angelgraves13 wrote:Either it's mastered that way or it's a new type of copy protection that's circumvented.
I got the same behavior as OP and they play not 100% correct at all. There is stutter all over the place.
angelgraves13
Where are you playing it? Pc? Set top box?
I find MPC HC plays MKV the best
Meister_Proper
Hardware player Popcorn Hour A-500 PRO.
Meister_Proper
I ripped the discs with the fox in order to see if this is a problem due to not using the latest AACS version in makemkv, but I'm still getting the same errors when using makemkv afterwards.
However, the .iso I created with the fox seem to play just fine with the eGreat A11 with full BD menu. At least from my limited tested so far.
So I guess its a new way of authoring a BD which makemkv does not support as of now?
angelgraves13
Vampire Diaries season 8 doesn’t have this issue. Neither does Superhirl S2 or Legends of Tomorrow S2. I just ripped them and they ripped with the AV Sync issue.
