[BD+ is supported in v1.4.8] "BD+ Feature unsupported"
Locked
27litres
Post by 27litres » Mon Mar 30, 2009 7:38 am
I just tried to open two new BluRay's with version 797, and got the following message:
- Using direct disc access mode
The blu-ray disc can't be opened by this BETA version. It contains the following unsupported feature: BD+
Any idea what this new feature is about (security?). & is there anything you can do to fix it?
Matt Devo
Re: "BD+ Feature unsupported"
Post by Matt Devo » Mon Mar 30, 2009 6:00 pm
BD+ is a second layer of security in addition to AACS encryption. It's not new, as it has been used since the fall of 2007. Best way to bypass it is to use AnyDVD-HD, then run MakeMKV as usual
27litres
Post by 27litres » Tue Mar 31, 2009 12:46 am
I did a bit of research & discovered AnyDVDHD myself. Brilliant little program!
Thanks, MakeMKV ripped the discs after that!
Post by mike admin » Tue Mar 31, 2009 7:56 am
BD+ support is planned in the near future. Not too many discs ise BD+ for the moment. For discs without BD+ you don't need AnyDVD, and you won't need AnyDVD once MakeMKV will have BD+ support.
Update: BD+ is supported starting from version 1.4.8 .
Locked
