Guardians of the Galaxy Vol. 2 error: Linux 1.10.6
nickieh
#1 Post by nickieh » Wed Aug 23, 2017 6:11 pm
Asus BW-12B1ST drive, Fedora 26:
MakeMKV v1.10.6 linux(x64-release) started
Internal error: openssl test 00FC failed
Highest AACS version is v57 , MKB saved as /home/rkh/.MakeMKV/MKB_v57_GUARDIANS_OF_THE_GALAXY_VOL_2.tgz
Suggestions?
Re: Guardians of the Galaxy Vol. 2 error: Linux 1.10.6
#2 Post by Woodstock » Wed Aug 23, 2017 8:09 pm
There have been some discussions in the Linux forum about this error and how to resolve it. Without openssl, there isn't much hope of decrypting the content, so resolving that issue should fix you up.
nickieh
#3 Post by nickieh » Thu Aug 24, 2017 1:57 pm
$ openssl version
OpenSSL 1.1.0f-fips 25 May 2017
I'd assume this is current enough; I keep my system updated....
nickieh
#4 Post by nickieh » Thu Aug 31, 2017 8:24 pm
$ openssl version
Saw the thread about the broken Fedora 26 version, and the fix on the negativio17 repository. Used that & getting same error. ???
MagmaiKH
#5 Post by MagmaiKH » Fri Sep 29, 2017 3:55 am
You need the EC (elliptical curve) support turned on in OpenSSL which theoretically prohibits binary distribution.
I read one post that said the patents have expired and Fedora started turning them on but go check your versions and see if they are new enough to get EC support.
(I had to rebuild a bunch of stuff on Gentoo to enable it because I was rolling without bindist.)
I just ripped my GotG2 disc so I know it works - I also used 1.10.7 so that might make a difference.
lightknight
#6 Post by lightknight » Sun Oct 01, 2017 8:03 pm
This a problem with the 4K release? I've been trying to rip that in Windows land, and haven't gotten anywhere. Cyberlink can't play it, because it requires some funky Intel BIOS extensions (which as I am running a Ryzen system...).
yorgo
#7 Post by yorgo » Mon Oct 02, 2017 12:12 pm
lightknight wrote:This a problem with the 4K release? I've been trying to rip that in Windows land, and haven't gotten anywhere. Cyberlink can't play it, because it requires some funky Intel BIOS extensions (which as I am running a Ryzen system...).
If I'm reading you correctly, you're trying to rip the UHD/4K disc not standard HD Blu-Ray, correct? If yes, can't be done as MakeMKV cannot decrypt AACS 2.0 (copy protection on all 4K discs) at this time, nothing can that I'm aware of.
