Current MakeMKV version will not run
rmarcks
#1 Post by rmarcks » Wed Aug 23, 2017 1:51 pm
I started up MakeMKV and received the 'software to old' message. I uninstalled that version, downloaded and installed the latest version. I still receive that message. I am on Windows 7, it has been updated, I did reboot after uninstalling the old version and before I installed the current version.
Any help is appreciated.
RKM
cxzaqwer
Re: Current MakeMKV version will not run
#2 Post by cxzaqwer » Wed Aug 23, 2017 2:11 pm
I'm having the same problem.
regelneef
#3 Post by regelneef » Wed Aug 23, 2017 2:48 pm
Yep I have the same problem... I'm on windows 10 BTW
SnowBrigade
#4 Post by SnowBrigade » Wed Aug 23, 2017 3:07 pm
Same problem here, not sure what's changed in the past couple days. This bought me what looks like another month or so at least: http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
regelneef
#5 Post by regelneef » Wed Aug 23, 2017 3:42 pm
That works perfectly ans solved my problem for now! Thnx SnowBrigade
killakel77
#6 Post by killakel77 » Wed Aug 23, 2017 5:57 pm
I had the same problem so I just went ahead and dropped the $50 for it. I had it free for a year now, I think that's enough.
rmarcks
#7 Post by rmarcks » Thu Aug 24, 2017 2:22 am
Great....that did work. I completely forgot that only beta was free and once out of beta, it become 'for profit' software.
My only question then becomes, I run both Linux and Windows, although my intent is to essentially abandon Windows once I retire...will the cost cover both or must I pay for each version?
RKM
#8 Post by Woodstock » Thu Aug 24, 2017 3:29 am
The registration key works for all three versions of MakeMKV.
