after doing some research, i foundout that makemkv wont recognize my drive.
here is the debug code
MakeMKV v1.10.6 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/karencarroza/MakeMKV_log.txt
DEBUG: Code 0 at B><ovS)|N@')cL:121263659
DEBUG: Code 117637427 at /Imp?XfdbK6<>V;M:121263567
DEBUG: Code 0 at /Imp?XfdbK6<>V;M:213131502
DEBUG: Code 0 at .zEbD5=fN0UL]XX:213131525
The program can't find any usable optical drives.
I have no idea what to ;-;
wont recognize external disk drive
Re: wont recognize external disk drive
MakeMKV asks the operating system about optical drives. Right now, your system says there are none.
Does the drive show up in Finder? What happens if you unplug the drive, then replug it?
britney98
it doesn't show up in the finder, yet it shows up when i go to >About this mac>storageWoodstock wrote:MakeMKV asks the operating system about optical drives. Right now, your system says there are none.
jbelkin800
Is it AC powered? Some non powered USB drive might not be available.
