Shortly after the initial sequence, maybe about 300Mb worth, it stalls. The reading rate is 0.0x, and stays at this for a long time. I had to abort. What causes it, a new code?
Waiting for an answer...
Thank you
trouble with Crazy Heart
Re: trouble with Crazy Heart
Please provide additional information per http://www.makemkv.com/faq/item/8/catid/6
Shadow2k
Does the .m2ts file name change before/after the stall happens? One of my discs showed a similar behavior whenever MakeMKV switched over to the next .m2ts file (Main feature was split into several .m2ts files).
The resulting MKV played fine though.
