installing makemkv 1.10.6
newbie45
#1 Post by newbie45 » Sat Aug 19, 2017 8:16 pm
A few months ago I installed MAKEMKV 1.10.5.1 in Ubuntu 16.04 using
sudo add-apt-repository ppa:heyarje/makemkv-beta
sudo apt-get update
sudo apt-get install makemkv-bin makemkv-oss
I now want to upgrade to 1.10.6 and downloaded
/download/makemkv-bin-1.10.6.tar.gz
/download/makemkv-oss-1.10.6.tar.gz
In which directory do I have to place the bin and oss tars in order to proceed
with the sudo make install for the bin and tar packages ?
andreapetrucci
Re: installing makemkv 1.10.6
#2 Post by andreapetrucci » Mon Aug 21, 2017 8:27 am
newbie45 wrote:A few months ago I installed MAKEMKV 1.10.5.1 in Ubuntu 16.04 using
sudo apt-get update
It doesn't matter where you put the tars, if your ubuntu-username is "YOURUSERNAME" then /home/YOURUSERNAME will be fine.
General instructions are here:http://www.makemkv.com/forum2/viewtopic.php?f=3&t=224, in the forum you can find posts with distro-specific instructions and tips.
I hope it helps.
newbie45
#3 Post by newbie45 » Thu Aug 31, 2017 10:01 pm
Thanks and sorry for my late reply, I will try this as soon as I have my system working again
newbie45
#4 Post by newbie45 » Fri Sep 01, 2017 2:10 pm
thanks Andrea
I have now installed makemkv 1.10.6 and it's working fine
