If you're experiencing rip errors, please read here first!
twainer
Re: If you're experiencing rip errors, please read here firs
Post by twainer » Wed May 03, 2017 8:42 pm
I use fedora 23. I purchased makemkv several versions ago, and it's never given me any problems through several versions of fedora and makemkv. Lately I've had trouble reading some disks at all, however. After reading the posts above, I began to suspect my drive was the culprit. I was seeing scsi errors as described and sometimes cleaning the disk would fix these.
Now the error is always the same; 'failed to save file' and the scsi error, can't read some segment (number changes as to which). I replaced the disks a couple times to no avail--so today I installed a brand new LG blu-ray writer/reader. Now, the error is constant on the latest disk:
Failed to save title 0 to file /The_Man_Who_Knew_Infinity_t00.mkv
Encountered 75 errors of type 'HashCheck Error' - see /errors/hashcheck/...
0 titles saved, 1 failed
This is a brand new, out of the box, never been used drive. It's hard to accept that this is a drive problem and I've already tried replacing the disk.
Any thoughts?
MVCurt
Post by MVCurt » Fri May 05, 2017 7:56 am
after many tries with makemkv i was able to backup the disc with dvdfab....not on first try though.
tomuser
Post by tomuser » Wed Jun 07, 2017 5:30 pm
I use an external BD drive to rip my BD discs. The drive is intended to be installed inside the PC, but I use a drive adapter USB3 system to avoid opening up my desktop PC.
After repeated failures with discs that looked perfrectly fine, I decided to replace the external drive with a new one.
Problem solved.
Drives become dirty, out of alignment, and have other problems as they age. This can also happen as a drive heats up and heats the disc. By replacing the drive, I was able to overcome all of the problems that I was experiencing with the old drive.
Scenario
Post by Scenario » Wed Aug 16, 2017 8:27 pm
MakeMKV used to work 90% of the time for me on Blu-ray discs. Now it's 10%.
I thought maybe my Samsung drive was bad, so I bought a brand new Pioneer drive. MakeMKV still fails to read most discs with either a "HARDWARE ERROR," a "MEDIUM ERROR," or an "Input/Output error."
I have also replaced several discs with different copies and they still fail to rip.
My conclusion is that the fault lies within MakeMKV. Something happened in recent builds, perhaps algorithmic or perhaps the read speed. Who knows?
But I can't continue to support or use MakeMKV until this is resolved and the app becomes more reliable for backing up Blu-ray discs.
Lovely Rita
Post by Lovely Rita » Wed Aug 16, 2017 10:59 pm
Scenario wrote: My conclusion is that the fault lies within MakeMKV. Something happened in recent builds, perhaps algorithmic or perhaps the read speed. Who knows?
I respectfully disagree.
The app is very reliable. I process approximately 1-2 Blu-Ray's each week and have done so since purchasing MakeMKV 4 years ago. I had no issues with the discs you referenced and have yet to see you list any of the errors other than "backup failed", which is of no help to any of the number of knowledgable users, here, more than willing to help troubleshoot.
Just because you replaced drives and the issues are still there does not conclude that it's MakeMKV. Are they external USB drives? I cannot tell you how many posts I've read, over time, concerning read issues with external drives.
Give us more to go on........ :wink:
Registered User :wink:
Buy MakeMKV
Scenario
Post by Scenario » Sat Aug 19, 2017 12:03 am
It doesn't really matter what kind of error shows up in the logs. MakeMKV's error-handling sucks in general.
If a disc won't rip, but it will play on a player, then the fault lies within the MakeMKV app. The app should handle these kinds of errors, by interpolation if necessary, when there are no visible defects on the disc and replacement after replacement disc yields the same failures.
I wound up sending my 2nd brand new Pioneer Blu-ray drive back to Amazon and ordered a 3rd one (a more expensive Pioneer model). We'll see how that goes, but I'm not hopeful.
I'm using Mac Sierra 10.12.6 on a 5K iMac.
The error is almost always something like:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00801.m2ts' at offset '241041408'
So next, instead of backing up the whole disc, I'll usually try to find the main title and just rip it. But 8 out of 10 times those errors will still happen -- often after an hour of ripping.
This only started happening with the current version of MakeMKV. Like I said above, last month it was rare to see these errors, and usually a replacement disc would fix the problem. But now, I'm trying up to 3 copies of the same movie and the failure rates are consistently high.
This tells me that it's not the discs and it's not my drive. IT'S THIS VERSION OF MAKEMKV.
yorgo
Post by yorgo » Sat Aug 19, 2017 1:33 am
Scenario wrote:It doesn't really matter what kind of error shows up in the logs. MakeMKV's error-handling sucks in general.
Fully agree with Lovely Rita and respectfully disagree with you. It does not suck, MakeMKV does exactly what it's supposed to do which is make a perfect bit-for-bit copy. That cannot be done with a disc that has errors, damage, etc. and therefore requires the application of error-correction. FYI, think about how much data is packed onto a disc; do you really think you can "see" a defect?
Scenario wrote:I wound up sending my 2nd brand new Pioneer Blu-ray drive back to Amazon and ordered a 3rd one (a more expensive Pioneer model). We'll see how that goes, but I'm not hopeful. I'm using Mac Sierra 10.12.6 on a 5K iMac.
You did not answer Lovely Rita's earlier question, is this an internal or external drive?
Scenario wrote:The error is almost always something like:
1. If the error happens at the same point each time you try to rip the disc, the error is on the disc.
2. It's rare but I've replaced discs multiple time (once as many as 5 times) until I got one that worked. If the error is in the mastering, it could be laid down on an entire die lot.
3. I've been using the current version since day 1 and and often, it is not performing worse, in any way, than previous versions.
So yes, I respect that you're experiencing a problem but I think you are aiming your frustration incorrectly.
Lovely Rita
Post by Lovely Rita » Sat Aug 19, 2017 3:35 pm
Scenario wrote:If a disc won't rip, but it will play on a player, then the fault lies within the MakeMKV app.
False - A standalone player will use error correction to skip bad areas whereas MakeMKV or any ripper for that matter requires no errors be present in order to rip a disc. Therefore, don't discount a disc may be damaged if you don't see something on the disc or it plays back fine.
I also use Mac Sierra 10.12.6 but on a homebuilt (Hackintosh) unit with a internal Pioneer drive.
Based on your assumptions that MakeMKV is the culprit why are there not more users posting with the same issue that you're having?
Post the complete log. There possibly could be other errors listed that could help determine the cause.
This error shows that the drive could not read what it needed to at 241041408 and if that error is repeated multiple times it points to a bad disc.
Have I had that error before? - Yes!
Have I ever had to return (exchange) a disc? - Yes!
But over the 4-5 years I've been using MakeMKV it's only happened 3-4 times.
Last month?
The current version 1.10.6 was released on May 25th and you joined the forum on July 30th.
Did you come into this using a previous version, 1.10.5? When did you update to 1.10.6? Approximately May 25th or "last month" (July)?
Have you tried going back to a previous version?
Older versions can be downloaded here: http://makemkv.org/download/old/
Buy MakeMKV
the_greenhorn
Post by the_greenhorn » Mon Aug 28, 2017 6:38 am
So if these rip errors are always the fault of the optical drive or the disc itself, then please help me explain my situation:
I have makemkv v1.10.6 [darwin(x86-release)] running on my Mac Pro, Sierra 10.12.5
I have VirtualBox running Ubuntu Desktop 17.04 and Ubuntu Server 16.04 in separate vm's - each running makemkv v1.10.6
When trying to rip a DVD within Ubuntu (either version) - i get the medium read errors (this is a log file from my auto ripper script):
Timestamp: Mon, 28 Aug 2017 01:06:06 -0500
ARM_CHECK_UDF=true
GET_VIDEO_TITLE=true
SKIP_TRANSCODE=false
RAWPATH="/media/sf_Movies/raw/"
MEDIA_DIR="/media/sf_Movies/Digital Movies/"
LOGPATH="/opt/arm/logs/"
LOGLIFE=1
SET_MEDIA_PERMISSIONS=false
CHMOD_VALUE=777
SET_MEDIA_OWNER=false
CHOWN_USER=
CHOWN_GROUP=
MINLENGTH="3600"
RIPMETHOD="mkv"
MKV_ARGS=""
HB_PRESET="High Profile"
DEST_EXT=mkv
HANDBRAKE_CLI=HandBrakeCLI
MAINFEATURE=false
HB_ARGS="--subtitle scan -F"
PLEX_SUPPORT=false
EMBY_REFRESH=false
EMBY_SUBFOLDERS=true
EMBY_SERVER=""
EMBY_PORT="8096"
EMBY_CLIENT="ARM"
EMBY_DEVICE="ARM"
EMBY_DEVICEID="ARM"
EMBY_USERNAME=""
EMBY_USERID=""
IFTTT_EVENT="arm_event"
LOG=$LOGPATH$LOGFILE
*** End config parameters ****
Starting Identify Script...
Deleting 0 old log files:
DEVLINKS=/dev/disk/by-id/ata-VBOX_CD-ROM_VB2-01700376 /dev/cdrom /dev/disk/by-label/THE_DEPARTED /dev/dvd /dev/disk/by-path/pci-0000:00:01.1-ata-2 /dev/disk/by-uuid/2006-12-21-17-12-28-00
DEVNAME=/dev/sr0
DEVPATH=/devices/pci0000:00/0000:00:01.1/ata2/host1/target1:0:0/1:0:0:0/block/sr0
DEVTYPE=disk
ID_ATA=1
ID_BUS=ata
ID_CDROM=1
ID_CDROM_CD=1
ID_CDROM_DVD=1
ID_CDROM_MEDIA=1
ID_CDROM_MEDIA_CD=1
ID_CDROM_MEDIA_SESSION_COUNT=1
ID_CDROM_MEDIA_TRACK_COUNT=1
ID_CDROM_MEDIA_TRACK_COUNT_DATA=1
ID_FOR_SEAT=block-pci-0000_00_01_1-ata-2
ID_FS_LABEL=THE_DEPARTED
ID_FS_LABEL_ENC=THE_DEPARTED
ID_FS_PUBLISHER_ID=WARNER\x20HOME\x20VIDEO
ID_FS_TYPE=udf
ID_FS_USAGE=filesystem
ID_FS_UUID=2006-12-21-17-12-28-00
ID_FS_UUID_ENC=2006-12-21-17-12-28-00
ID_MODEL=VBOX_CD-ROM
ID_MODEL_ENC=VBOX\x20CD-ROM\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20
ID_PATH=pci-0000:00:01.1-ata-2
ID_PATH_TAG=pci-0000_00_01_1-ata-2
ID_REVISION=1.0
ID_SERIAL=VBOX_CD-ROM_VB2-01700376
ID_SERIAL_SHORT=VB2-01700376
ID_TYPE=cd
MAJOR=11
MINOR=0
SUBSYSTEM=block
TAGS=:seat:uaccess:systemd:
USEC_INITIALIZED=1397459
identified udf
found THE_DEPARTED on /dev/sr0
identified udf as video
Obtained Title The Departed (2011)
got to here
HAS_NICE_TITLE is true
video title is now The Departed (2011)
video type is fail
Starting video_rip.sh
Video Title is The Departed (2011)
Ripping video THE_DEPARTED from /dev/sr0
Using mkv method of ripping.
MSG:1005,0,1,"MakeMKV v1.10.6 linux(x64-release) started","%1 started","MakeMKV v1.10.6 linux(x64-release)"
DRV:0,2,999,1,"DVD-ROM VBOX CD-ROM 1.0","THE_DEPARTED","/dev/sr0"
DRV:1,256,999,0,"","",""
DRV:2,256,999,0,"","",""
DRV:3,256,999,0,"","",""
DRV:4,256,999,0,"","",""
DRV:5,256,999,0,"","",""
DRV:6,256,999,0,"","",""
DRV:7,256,999,0,"","",""
DRV:8,256,999,0,"","",""
DRV:9,256,999,0,"","",""
DRV:10,256,999,0,"","",""
DRV:11,256,999,0,"","",""
DRV:12,256,999,0,"","",""
DRV:13,256,999,0,"","",""
DRV:14,256,999,0,"","",""
DRV:15,256,999,0,"","",""
MSG:3007,0,0,"Using direct disc access mode","Using direct disc access mode"
MSG:3028,0,3,"Title #1 was added (38 cell(s), 2:30:50)","Title #%1 was added (%2 cell(s), %3)","1","38","2:30:50"
MSG:3025,0,3,"Title #2 has length of 12 seconds which is less than minimum title length of 3600 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","2","12","3600"
MSG:3025,0,3,"Title #3 has length of 12 seconds which is less than minimum title length of 3600 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","3","12","3600"
MSG:3025,0,3,"Title #4 has length of 21 seconds which is less than minimum title length of 3600 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","4","21","3600"
MSG:3025,0,3,"Title #5 has length of 146 seconds which is less than minimum title length of 3600 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","5","146","3600"
MSG:3025,0,3,"Title #6 has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","6","7","3600"
MSG:3025,0,3,"Title #7 has length of 109 seconds which is less than minimum title length of 3600 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","7","109","3600"
MSG:3025,0,3,"Title #8 has length of 278 seconds which is less than minimum title length of 3600 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","8","278","3600"
MSG:3025,0,3,"Title #9 has length of 148 seconds which is less than minimum title length of 3600 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","9","148","3600"
MSG:2003,0,3,"Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '2048'","Error '%1' occurred while reading '%2' at offset '%3'","Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR","/VIDEO_TS/VTS_01_1.VOB","2048"
MSG:2003,16777216,3,"Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '2048'","Error '%1' occurred while reading '%2' at offset '%3'","Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR","/VIDEO_TS/VTS_01_1.VOB","2048"
MSG:2023,16777216,3,"Encountered 36 errors of type 'Read Error' - see /errors/read/","Encountered %1 errors of type '%2' - see %3","36","Read Error","http://www.makemkv.com/errors/read/"
MSG:5010,0,0,"Failed to open disc","Failed to open disc"
STAT: THE_DEPARTED ripped in 0 hours, 0 minutes and 17 seconds.
/opt/arm/video_transcode.sh "/media/sf_Movies/raw//The Departed (2011)_20170828_010608" "The Departed (2011)" "true" "fail" 20170828_010608
THE_DEPARTED sent to transcoding queue...
Start video transcoding script
transcoding with a nice title
directory already exists... adding timestamp
Transcoding all files.
STAT: transcoded in 0 hours, 0 minutes and 0 seconds.
Pushbullet notifications not enabled
IFTTT notifications not enabled
Pusover notifications not enabled
*** Start config parameters ****
Timestamp: Mon, 28 Aug 2017 01:06:25 -0500
ARM_CHECK_UDF=true
LOGLIFE=1
CHMOD_VALUE=777
CHOWN_USER=
CHOWN_GROUP=
MINLENGTH="3600"
RIPMETHOD="mkv"
MKV_ARGS=""
DEST_EXT=mkv
MAINFEATURE=false
PLEX_SUPPORT=false
EMBY_REFRESH=false
EMBY_SERVER=""
EMBY_PORT="8096"
EMBY_CLIENT="ARM"
EMBY_DEVICE="ARM"
EMBY_DEVICEID="ARM"
EMBY_USERNAME=""
EMBY_USERID=""
DEVLINKS=/dev/disk/by-path/pci-0000:00:01.1-ata-2 /dev/disk/by-id/ata-VBOX_CD-ROM_VB2-01700376 /dev/dvd /dev/cdrom
DEVNAME=/dev/sr0
DEVTYPE=disk
ID_ATA=1
ID_BUS=ata
ID_CDROM=1
ID_CDROM_CD=1
ID_CDROM_DVD=1
ID_REVISION=1.0
ID_TYPE=cd
MAJOR=11
MINOR=0
SUBSYSTEM=block
SYSTEMD_READY=0
TAGS=:uaccess:seat:systemd:
drive seems empty, not ejecting
I have tried this with multiple DVDs - all the same result.
HOWEVER - when i insert these SAME DVDs and use makemkv on my Mac (host) - it reads ALL of them with no problem. Same version running on host and vm's.
So i'm not saying that i don't have something configured wrong inside of Ubuntu installs - but i have not figured out the problem yet. But this leads me to believe that not ALL medium read errors are related to dirty discs or optical drives that need cleaning.
Yes, i completely understand the difference between playing a dvd and ripping one - I've done a lot of ripping in my time, and from time to time i definitely have had problems with dirty discs and several optical drives.
But the evidence i'm seeing is that makemkv is giving me different results while using the same version of software, same DVDs and same optical drive.
Of course i have not ruled out that there may be an inherent problems with makemkv and the ubuntu versions i'm running - all i'm saying is that i've seen on so many forums (and even MakeMKV's website) where the ONLY answer to read errors is bad discs or bad optical drives.
I appear to have an exception, and i'm certain i'm not the only one that has ever encountered media read errors when it wasn't really media read errors.
Thanks for reading!
the_greenhorn
Post by Woodstock » Mon Aug 28, 2017 1:36 pm
MakeMKV is receiving the read errors from the operating system, and reporting them - which means the "virtual drive" is having trouble getting valid data from the virtualized DVD.
Does the VM that is failing have full access to the drive?
the_greenhorn
Post by the_greenhorn » Mon Aug 28, 2017 3:15 pm
That's a good question. i have tried setting host drive as my optical with both "passthrough" checked and not checked. I can use udevadm to grab header info from DVD, so Ubuntu is seeing the drive, but evidently doesn't have full access. will try to research why. Thanks for the reply!
yorgo
Post by yorgo » Fri Oct 27, 2017 11:07 am
Seen a few posts recently asking for help on a failed rip without much information. I've revised the original post to include the following:
"Additionally, if you feel the need to post about a rip error on the forum, please include the ENTIRE error report from the "conversion screen"; without this, it will be difficult for a forum member to provide accurate guidance."
deurenkletser
Post by deurenkletser » Thu Nov 16, 2017 7:11 pm
I've also had some problems with read errors. Tried everything, but what helped the best was, and that's very strange, shaking my desktop when the reading error occured.
You can see when it stops writing the file. When it stopped, it gently shaked my dekstop and MakeMKV just continued...
All other times it failed creating an MKV (tried 2 discs, 2 blu-ray readers). So maybe this helps skip the problem. It helped me.
It also helps to open the tray when the error occurs and then close it again. MakeMKV continues were it left. Sometimes it just continues, sometimes not...
Qun Mang
Post by Qun Mang » Mon Dec 04, 2017 12:42 am
I have been trying this program mostly in vain, and all I can do is add to the voices saying they are getting errors ripping. I'm not going to try and place blame anywhere, but certainly every disc cannot be bad, so whether it's the drive, the program not liking my system, or whatever it seems I cannot do what should be a simple task (well, two simple tasks- ripping 3D Blu-rays then using another program to convert the result into something the Gear VR likes). I have tried two different drives on my Windows 10 machine and one drive successfully ripped a single movie, and the new drive I bought to replace it so far had been able to rip nothing. The original is a USB2 external bluray ripper which I read here will go offline if the ripping speed gets too high. It does not have a means to power it externally, and I supposed even a Y-cable didn't supply the required power. The new drive is an internal writer (seems that bluray writers are the standard now?)- the LG WH16NS40. Two discs I tried wouldn't even load the playlists while the others choke at some point during the ripping process. I will admit that these are from the library, but I did clean the discs before ripping and saw no visible scratches on them. I did try the suggestion someone mentioned of ejecting the disc while it's being processed then reloading it, but that just crashed Windows (both drives I tried).
Is there something I am missing? Am I supposed to set up the drive somehow perhaps? All I did was turn off the computer, pull out the internal DVD drive and put the new one in its place using the same cables. Windows recognized it no problem, and so did MakeMKV.
All I want to do is watch 3D movies on my Gear VR. Looks like I will have to try something else. Thanks for a program that others can use at least. Maybe I have just been unlucky and I will eventually find a disc that rips successfully, but this has certainly been frustrating.
[EDIT] Here's one of the last logs (the first movie I manually stopped after the errors started, the second I let run to fail completion):
MakeMKV v1.10.8 win(x64-release) started
Title #00131.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00200.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #0
Title #00311.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00312.mpls was added as title #1
File 00313.mpls was added as title #2
File 00314.mpls was added as title #3
Title #00310.mpls has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00201.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00301.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00302.mpls was added as title #4
File 00303.mpls was added as title #5
File 00304.mpls was added as title #6
Title #00300.mpls has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00306.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00307.mpls is equal to title 00302.mpls and was skipped
Title 00308.mpls is equal to title 00303.mpls and was skipped
Title 00309.mpls is equal to title 00304.mpls and was skipped
Title #00131.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00200.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02122.m2ts has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02127.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02128.m2ts has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02132.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01741.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 7 titles into directory E:/Video/(movie 1)
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/02070.m2ts' at offset '12449642496'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '12449642496'
Error 'OS error - {No Disk} There is no disk in the drive. Please insert a disk into drive hs' occurred while reading '\Device\CdRom0' at offset '12449642496'
Error 'Internal error - Operation was cancelled (112)' occurred while reading '/BDMV/STREAM/02070.m2ts' at offset '12449642496'
Failed to save title 0 to file E:/(movie 1)_t00.mkv
Encountered 31 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 7 failed
File 00031.mpls was added as title #0
File 00020.mpls was added as title #1
Title #00020.mpls(1) has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.mpls has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 2 titles into directory E:/Video/(movie 2)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '4144164864'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '4144164864'
Failed to save title 1 to file E:/Video/(movie 2)_t01.mkv
Encountered 51 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
1 titles saved, 1 failed
Interesting this line: "Evaluation version, 30 day(s) out of 30 remaining." The program asks me every time I start it if I want to start the 30 days- is this normal behavior?
Post by Woodstock » Mon Dec 04, 2017 1:44 am
The most important lines start here:
Your drive went off-line. This is consistent with an USB-powered drive that is not getting enough power to spin at full speed. When the rip speed reaches the power limit, the drive shuts down and resets.
If it is a USB drive that is powered by the USB port, make sure you are plugging into a full-powered hub (external power if it isn't in a desktop computer), especially if it came with a two-head cable. Plugging both heads into a USB hub that doesn't have full power available on all ports is not going to work.
At this time there is no way to limit MakeMKV's ripping speed, other than keeping it from being able to write faster than it can read. The only way I can think of to force it to slow down is to write the output to a slow device, like a USB flash drive that is big enough to hold the output file.
If you go with the flash drive route, it needs to be formatted in something other than FAT32, such as NTFS (if you're on a Windows or Linux system) or ExFAT (Mac or Windows system). In my testing, this limits the read speed to about 3.4x before this message starts appearing:
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
This should be well within the power limits for most USB-powered BD/DVD drives.
