The Roadhouse and Kickboxer do not convert
mike_mgoblue
#1 Post by mike_mgoblue » Mon Aug 14, 2017 11:04 am
I just thought I would point out I have successfully converted eight Blu-ray discs so far.
Unfortunately, I have encountered problems with two Blu-ray discs.
* The Roadhouse
* Kickboxer
I have tried multiple times with both of them.
Re: The Roadhouse and Kickboxer do not convert
#2 Post by Woodstock » Mon Aug 14, 2017 12:49 pm
No guesses based on zero information.
See the FAQ link in my signature. Without at least knowing what error messages you're getting, we have nothing to go on.
mike_mgoblue
#3 Post by mike_mgoblue » Tue Aug 15, 2017 8:14 pm
I removed the checkmarks from the subtitles in Roadhouse and I was able to get Roadhouse to convert to MKV successfully. I'm not sure if removing the checkmarks made the difference or not.
Kickboxer still does not work, no matter what is removed. I have attached a screenshot of the error messages.
Also, the movie Underworld experienced problems, too.
Well, I tried to attach the screenshots, but it didnt work
mike_mgoblue
#4 Post by mike_mgoblue » Tue Aug 15, 2017 8:34 pm
HERE IS THE TEXT THAT APPEARED FOR THE MOVIE "UNDERWORLD: EXTENDED CUT"
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17485295616, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17485295616-17485301760, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17485301760, attempting to work around
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '18019467264'
Error 'OS error - {Wrong Volume} The wrong volume is in the drive. Please insert volume hs into drive hs' occurred while reading '\Device\CdRom1' at offset '17485307904'
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17485314048, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17485314048-17485320192, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17485320192, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17485320192-17485326336, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17485326336, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17485983744, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486247936, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486254080, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486254080-17486260224, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486260224, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486260224-17486266368, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486266368, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486272512, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486272512-17486278656, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486278656, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486278656-17486284800, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486284800, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486284800-17486290944, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486290944, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486290944-17486297088, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486297088, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486303232, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486303232-17486309376, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17486309376, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488932864, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488932864-17488939008, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488939008, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488939008-17488945152, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488945152, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488945152-17488951296, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488951296, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488951296-17488957440, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488957440, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488957440-17488963584, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488963584, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488963584-17488969728, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488969728, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488969728-17488975872, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488975872, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488975872-17488982016, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488982016, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488982016-17488988160, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488988160, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488988160-17488994304, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488994304, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17488994304-17489000448, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17489000448, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17489264640, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17489264640-17489270784, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17489270784, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 17489276928, attempting to work around
Error 'Scsi error - NOT READY:MEDIUM NOT PRESENT - TRAY OPEN' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '18019719168'
Error 'OS error - The request was aborted' occurred while reading '\Device\CdRom1' at offset '17489283072'
Failed to save title 0 to file C:/Video/LOGICAL_VOLUME_ID/title00.mkv
Encountered 394 errors of type 'HashCheck Error' - see /errors/hashcheck/...
0 titles saved, 1 failed
#5 Post by Woodstock » Wed Aug 16, 2017 2:19 am
If removing a subtitle track made a difference, that would indicate that the read error is in a spot where "just" that subtitle track existed. While I have personally encountered that problem, it's rather rare.
On Kickboxer, do the locations of the read errors come up the same each run, or do they move about a little? If they are always the same, even after cleaning, then that points to a physical defect in the disk. If they move around, there is the possibility that the drive CAN read the disk, but not consistently. Increasing the number of retries to make ( Preferences->IO ) can SOMETIMES help with disks like this.
But the "Tray open" errors concern me - the operating system is telling MakeMKV that the disk was ejected, but then says it is loaded. That should not happen, UNLESS you opened the drive mid-read, and it should stop MakeMKV, rather than just be temporary.
mike_mgoblue
#6 Post by mike_mgoblue » Wed Aug 16, 2017 12:31 pm
First, I will answer your question about Underworld. I believe I did click the "Eject" button on the Blu-ray drive, because nothing else was working. So that is probably why that message was displayed.
Second, I will answer your question about Kickboxer. ... With Kickboxer, the problem occurs in the same spot every single time. I have tried about ten times now and it always happens after 11,000 has been reached. Suddenly the disc will slow down from reading at about 8.7x speed to about 2x, and then completely stop.
Here is the message I just copied from Kickboxer:
MakeMKV v1.10.6 win(x64-release) started
File 00003.mpls was added as title #0
Title 00004.mpls is equal to title 00003.mpls and was skipped
File 00001.mpls was added as title #1
File 00010.m2ts was added as title #2
File 00006.m2ts was added as title #3
File 00005.m2ts was added as title #4
File 00001.m2ts was added as title #5
Saving 1 titles into directory C:/Video/Kickboxer
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11557337088'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11557601280'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '11557601280'
Failed to save title 1 to file C:/Video/Kickboxer/title01.mkv
Encountered 12 errors of type 'Read Error' - see /errors/read/
mike_mgoblue
#7 Post by mike_mgoblue » Wed Aug 16, 2017 1:13 pm
I just changed the Preferences IO number of Retries from 5 to 25. ... Unfortunately, that did not solve the problem with Kickboxer.
For some reason the Blu-ray drive was reading at a rate of 2.0x the entire time, rather than up to 8.7x as it normally does.
The list of problems was much longer this time, and it appears the problem occurred sooner rather than the usual spot.
Here is the text:
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10835988480, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836000768, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836000768-10836006912, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836006912, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836006912-10836013056, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836013056, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836013056-10836019200, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836019200, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836019200-10836025344, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836025344, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836025344-10836031488, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836031488, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836037632-10836043776, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836043776, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836043776-10836049920, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836049920, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836049920-10836056064, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836056064, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836056064-10836062208, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836062208, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836062208-10836068352, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836068352, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836068352-10836074496, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836074496, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836074496-10836080640, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836080640, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836080640-10836086784, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836086784, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836086784-10836092928, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836092928, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836092928-10836099072, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836099072, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836111360, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836178944, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836178944-10836185088, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836185088, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836185088-10836191232, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836191232, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836191232-10836197376, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836197376, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836209664, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836209664-10836215808, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836215808, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836215808-10836221952, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836221952, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836221952-10836228096, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836228096, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836228096-10836234240, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836234240, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836234240-10836240384, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836240384, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836240384-10836246528, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836246528, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836246528-10836252672, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836252672, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836252672-10836258816, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836258816, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836258816-10836264960, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836264960, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836264960-10836271104, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836271104, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836271104-10836277248, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836277248, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836277248-10836283392, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836283392, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836283392-10836289536, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836289536, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836289536-10836295680, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836295680, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836295680-10836301824, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836301824, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836301824-10836307968, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836307968, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836639744, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836639744-10836645888, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836645888, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836645888-10836652032, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836652032, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836652032-10836658176, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836658176, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836658176-10836664320, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836664320, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836664320-10836670464, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836670464, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836670464-10836676608, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836676608, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836676608-10836682752, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836682752, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836682752-10836688896, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836688896, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836688896-10836695040, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836695040, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836695040-10836701184, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10836701184, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 10833217536, attempting to work around
Encountered 26 errors of type 'Read Error' - see /errors/read/
Encountered 478 errors of type 'HashCheck Error' - see /errors/hashcheck/...
#8 Post by Woodstock » Wed Aug 16, 2017 1:27 pm
When the errors occur at the same spot every time, it's something about the disk that is the problem.
The error "corrupt or invalid" USUALLY means that the drive did not report a read error, but what was returned was not valid data. Kind of like asking for a phone number and getting getting back 00000000000000 instead.
There are some drives that will not report errors if they can read SOMETHING, even if the error correction code built into the disk says it is corrupt.
Are these disks new? I'd recommend exchanging them if they are.
mike_mgoblue
#9 Post by mike_mgoblue » Wed Aug 16, 2017 1:59 pm
I've had Kickboxer for several years.
I've also had Captain America and Underworld for several years. They play fine on players, but for some reason they just won't convert.
I just tried the strategy of Copying and Pasting the file of 00000 from the BDMV Stream folders on the disc. The first 78% went very quickly, and then stopped. This is when the MakeMKV would normally stop. However, using this Copy and Paste method, the data continued to transfer at a rate of 1.39MB/sec. Actually, it said 1.39MB per second, then 0, then 300kb/s and they would flip flop. However, even at that slow rate, it eventually made it to 80%. ... I thought that this might "eventually" reach 100%, even though it might take several hours. But at 84% it came to a complete stop and only transferred 0. At that point it eventually gave a message that said:
An unexpected error is keeping you from copying the file. If you continue to receive this error, you can use the error code to search for help with this problem. Error0x8007045D. The request could not be performed because of an I/O device error.
#10 Post by Woodstock » Wed Aug 16, 2017 5:44 pm
It would be interesting to try it in a different drive - I was re-ripping a series overnight, and 4 of the disks failed to even load in the primary drive, but worked just fine in a different one.
