Captain America - The First Avenger Error
mike_mgoblue
#1 Post by mike_mgoblue » Wed Aug 16, 2017 3:48 am
Hi tried to convert Captain America - The First Avenger. However, this was the third Blu-ray that had errors on it.
My hardware is not the problem, because I have been able to successfully convert over 20 Blu-rays.
I bought this Blu-ray new and it is in 100% perfect condition. It does not have a scratch on it. The movie also plays on a blu-ray player.
Here is what was said after the messages started appearing on the screen:
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23741282304, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23741313024, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23741657088, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23742640128, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23742922752, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23742959616, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23743229952, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23743297536, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23743574016, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23743586304, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23744212992, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23744280576, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23744569344, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23744600064, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23744870400, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23753650176, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23753717760, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23754307584, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23754657792, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23754657792-23754663936, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23754663936, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23754663936-23754670080, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23754694656, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23755616256, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23755683840, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23755960320, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23755960320-23755966464, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23755966464, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23755966464-23755972608, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23755972608, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23755972608-23755978752, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23755978752, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23755978752-23755984896, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23755997184, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23756009472, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23756273664, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23756961792, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23758239744, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23758577664, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23758608384, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23758958592, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23759013888, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23759241216, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23759241216-23759247360, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23759247360, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23759278080, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23759548416, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23759616000, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23760218112, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23760248832, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23761188864, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23772315648, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23772315648-23772321792, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23772321792, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23773575168, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23775897600, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23775928320, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23776247808, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23776247808-23776253952, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23776253952, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23786944512, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23832360960, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23739654144, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23739684864, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 23740674048, attempting to work around
Failed to save title 0 to file C:/Video/Captain_America_The_First_Avenger/Captain_America_The_First_Avenger_t00.mkv
Encountered 32 errors of type 'HashCheck Error' - see /errors/hashcheck/...
0 titles saved, 1 failed
